I konw there is a topic on this but it dont answer my question
there is a How to on changing your dashlights to JDM style red i was wondering if there is any way of instead of replacing bulbs, replace with LED ???? it would be much better and brighter if it is possible
thanx for the replys
Mark
Mark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Farkis »</TD></TR><TR><TD CLASS="quote">i did and i cant find it again
and im pretty sure it had nuthing on changing to led</TD></TR></TABLE>
Yeah it did. It had plenty of people asking about using LEDs. And some people came to the conclusion that using LEDs would give you splotchy coloring. (really dark in some places really bright in others) If you look in the FAQ thread on the top of the forum it will be in there. And then read through every page.
Actually there is a LED made just for dash lighting. I tried it in a spare cluster I had laying around and it worked pretty nice. Unfortunetly tho the LEDs were for a different sized holder and wouldent fit propperly into my cluster. Ill look up the EXACT LED when I get out of class.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">
Yeah it did. It had plenty of people asking about using LEDs. And some people came to the conclusion that using LEDs would give you splotchy coloring. (really dark in some places really bright in others) If you look in the FAQ thread on the top of the forum it will be in there. And then read through every page.</TD></TR></TABLE>
Correct. Using LED's for this application would not be "much better and brighter". The result is as you described above -- uneven light distribution and inadequate illumination. Traditional bulbs will produce the best results.
areagan1
Nov 10, 2007 11:27 AM
le0ftw
Jan 23, 2007 08:42 PM
