Stock springs ; front vs. rear
Okay, did search and now I'm confused ; Which springs goes were?
It's the long ones in the front and the short ones in the rear, right?
And left/right or up/down doesn't matter, right?
Its 2 in the morning here. If I can remember correctly, long in front due to the extra weight. The springs also have progressive spring rates which makes them slide over the strut a certain direction. One of the ends of the coil should be ground flat to seat evenly on the upper mount. The bottom end looks like the coil was cut off. Hmmm. So hard to explain without pictures.
Maybe some one on the east coast who should be getting out of bed from a good nights sleep can help you out. Time difference is six hours.
red92EG
Sep 16, 2006 02:02 PM
Wazup
Suspension & Brakes
Feb 6, 2006 10:46 PM
