Are resistor box and distributor plugs needed for mpfi swap?
Old May 19, 2005 | 02:12 AM
crex23's Avatar
Default Are resistor box and distributor plugs needed for mpfi swap?
Is it necessary to have the resistor box plug and Si distributor plug for a mpfi swap? Can I just run the wires together or do I need the plug in the middle? I'm having a hard time locating just these two plugs, and I don't want to pay $100 for a complete wiring harness just to chop it up for these two plugs. TIA
Old May 19, 2005 | 04:49 AM
EFvtec Yo!'s Avatar
Default Re: Are resistor box and distributor plugs needed for mpfi swap? (crex23)
if you are staying obd0, you have to have the resistor box on a mpfi setup.
Old May 19, 2005 | 05:40 AM
CRX_Control's Avatar
Default Re: Are resistor box and distributor plugs needed for mpfi swap? (EFvtec Yo!)
you just need a mpfi distributor for obd0 . like si , hf will both work.Go to the junkyard for the plugs , its free pretty much.
Old May 20, 2005 | 01:17 AM
crex23's Avatar
I've called all the junkyards in my area, and they don't have what I need. I'm buying a used dizzy out of a 90 Civic Si, will I need to get a 90-91 dizzy plug or will any 88-91 plug work? Also, I've got an Si resistor box (the one with the fins). Should I try posting in the classifieds for the plugs?
Old May 20, 2005 | 02:47 AM
just buy new plugs.. they only like 30$ and you get the right one too. Cause i know plugs differ from one to another and it doesnt matter if they the same obd either .
89D15CRXDX
Oct 23, 2006 03:28 PM
crex23
Jun 16, 2005 07:36 PM
dingusjt
Oct 9, 2003 06:02 AM
vtecrx
Jul 22, 2002 02:16 PM
OldSchoolHatch
May 24, 2002 09:19 AM
