Jeep in OK: 97 TJ, Very Low Miles, Atlas II, F/R Ford 9", etc...
I'm located in Tulsa, Ok. White 1997 Jeep TJ Sahara, white factory hard-top and full doors, as well as factory soft top and half doors. Just under 26,000 miles, second owner, clear title. Selling because of work relocation. I need a daily highway driver. Asking $13,500 or best offer.
This Jeep is adult owned and driven, it has been well maintained and taken very good care of. I purchased the Jeep 4 months ago nearby from the original owner who took meticulous care of it including keeping upgrade and maintenance records. You'll be hard pressed to find a Jeep that received as much care and attention.
It does have a few very minor dings and scratches but no body damage or dents. The Jeep has been driven off-road about 5-10% of the its total miles but it has never been abused such as jumping or hard hit bumps or any roll-overs. The motor & drive-train drives strong, steers very straight, and rides on the street very smooth with no vibrations.
The interior is practically immaculate, the seat upholstery front and rear are in great condition, no wear, tears, or stains, seats have always had seat covers on them since new, (I recently removed the seat covers for photos). I have receipt & documentation for most (maybe all) parts and modifications.
Contact me at: peter.gornell@gmail.com
*4 Liter 6 cylinder engine
*3 Speed Auto with deep tranny pan
*Ice Cold AC
*Advance Adapters Atlas II 3.8:1 transfer case
*Mile Marker 12,000 lbs hydraulic winch & Master Pull 3/8"x100' synthetic winch rope
*Olympic 4X4 front Rock Winch Bumper
*PSC TC pump to P pump conversion & power steering reservoir
*Grand Wagonner steering box
*Black Herculiner applied to the tub, optional choice of running with or with out carpet
*MORE sport cage
*Durango rear bumper and tire carrier
*Durango stainless steel rocker guards with removable steps
*Wet Okole seat covers front and rear
*Alpine CD/MP3 player
*Polk MOMO speakers 5.25 (installed), 6.5 (not installed...for soundbar)
*5 American Racing AR-767 Series wheels 8x16", 5 on 5.5" bolt pattern
*4 Goodyear MT/R 285/75R16 (33x11.50) tires excellent condition about 5000 miles
*1 BF Goodrich Mud Terrain 285/75R16 spare tire (lots of good tread left)
*Cobra 75 WX ST CB & Fire-Stick antenna
*Currie Steering gear brace
*Kilby Enterprises rear gas tank skid
*Transmission cooler and temperature gauge
*Poweraid throttle body spacer
*AirRAID cold air intake
*Turbo City hi-flow throttle body
*Turbo City high flow thermostat housing
*1997 Jeep Factory Full Service Manual and Parts Manual (books & CDs)
*OEM Sahara decals replaced with OEM Australian Renegade decals
*Swingman Twister 3-bike hitch mount bike rack...brand new
__________________________________________________ _____________
3" suspension lift consisting of
* Currie adjustable control arms uppers & lowers
* Currie front & rear adjustable track bars
* Currie Anti Rock Front Sway Bar System
* TeraFlex 3" spring and bump stops
* Edelbrock ISA shock absorbers for 3" lift (shocks being upgraded tomorrow for more travel)
9" rear-end (5 on 5.5" bolt pattern 4.10 gear ratio 60 ½" outside hub to outside hub) consist of:
* Currie Performance 1.5" diameter 35 spline axles shafts
* Stange Engineering 3rd member with Detroit Locker
* Ford 8.8 rear disk brakes
* Jeep ZJ brake combination valve (for rear disk brake conversion)
* 1330 CV rear drive shaft
9" front-end (5 on 5.5" bolt pattern 4.10 gear ratio 60 3/4" outside hub to outside hub) consist of
* Warn Premium Hubs
* Moser 31 spline inner axle shafts
* Warn 19 spline outer axle shafts
* Spicer 5-760X u-joints with full circle retaining C clips
* Nodular "N" 3rd member with Detroit TrueTrac (gear driven limited slip)
* Custom steering linkage consist of the Chevy/GMC tie-rod ends & DOM tubing
* GM/Jeep calipers and rotors
* 1310 CV front drive shaft
Soft-top consists of:
* Complete Black Denim factory soft-top and L&R and rear windows
* L&R complete matching half doors
* Like new Bestop upper door sliders part # 51787 (match the * factory soft-top)
The OEM black denim factory soft top and frame, are in excellent condition, absolutely no holes or tears, all zippers work. Includes L&R side and rear windows, they are used, and have minor surface scratches, I would rate them 9 out of 10.
*Ice Cold AC
*MORE sport cage
* Warn Premium Hubs
TurboT
Jul 6, 2004 08:11 AM
