Help with LS/Vtec
Old May 18, 2005 | 11:02 PM
si2kcivic's Avatar
Default Help with LS/Vtec
I was told to come here for some ls/vtec help. I just bought a B18A block for a good deal and had ALOT of questions. As far as a cylinder head goes, questions answered. But what kind of internals can I use on this block? GSR or ITR internals? What kind of crank? rods? pistons? I need lots of help on this. Thanks in advance.
Old May 19, 2005 | 12:52 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Help with LS/Vtec (si2kcivic)
Search and you will find tons of threads covering this
Old May 19, 2005 | 08:17 AM
DavidT or VajT's Avatar
Dude, with all your questions I wouldn't build a Ls-Vtec if I were you. ****'s gonna happen, and all your money will go to waste. Just go with a B16/B18c...everything's already there for reliablility and power.
Old May 19, 2005 | 08:33 AM
si2kcivic's Avatar
Default Re: Help with LS/Vtec (DavidT or VajT)
Thats why I'm asking questions now. If it comes down to it I will sell the block and get another. But before the money is spent research must be done so I can do it right.
Old May 19, 2005 | 08:34 AM
97L-esVeeTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidT or VajT &raquo;</TD></TR><TR><TD CLASS="quote">Dude, with all your questions I wouldn't build a Ls-Vtec if I were you. ****'s gonna happen, and all your money will go to waste. Just go with a B16/B18c...everything's already there for reliablility and power.</TD></TR></TABLE>
I agree. The ls/vtec conversion is not for everybody, it takes alot more than just slapping a vtec head on a non-vtec block. When i first started my build, if i had known then what i know now i would have opted for a gsr or type r swap. Do a search and make sure you know what you are getting into before you spend your hard earned bucks on a swap Good luck with your build.
blinddan
20
Feb 15, 2007 07:04 PM
91redteg
Jan 26, 2007 04:56 PM
wht92teg
Aug 6, 2006 07:48 PM
B18C5_EJ
Jun 4, 2006 11:15 AM
sloweredcivic
19
Oct 8, 2004 08:21 PM
