washington oregon h22 head wtb or fs bent valves broken camshaft will trade or buy good H22
i got head off of h22a with bent exauhst valves
all the valvetrain is there
including cam caps and rails
and the head only
im keeping all the bolts
no camshafts
no valve cover no dizzy and no manifold
make offer
easy fix for someone who done this before
it comes with dual valve springs
exahust camshaft broke in 3 pieces and bent the valves in the proces
one of the valve springs are not on the head
but i have them with retainer just dont have the key to lock them in place
here are some pics
http://www.myphotospace.com/up...9.JPG
http://www.myphotospace.com/up...2.JPG
http://www.myphotospace.com/up...4.JPG
http://www.myphotospace.com/up...6.JPG
http://www.myphotospace.com/up...8.JPG
http://www.myphotospace.com/up...7.JPG
http://www.myphotospace.com/up...0.JPG
i want to either trade this head for a good one and cash on top or just buy good h22 head
dont have to be complete or either buy good stock exhaust valves and good camshafts
i might have some skunk2 cam gears up for sale and maybe more h22 parts
and the head only
no camshafts
make offer
here are some pics
i will have a lot of left overs
from h22 parts
complete intake manifold with throttle body fuel rail injector only missing iacv
extra black valve cover sold
clean h22 head with bent exhaust valves no cam caps
h22 good intake type S cam sold
2 skunk2 cam gears sold
vtec solenoid sold
and a distributor obd1
power steering bracket sold
autometer boost and a/f guages with eg dual pod no longer for sale
Modified by dmakarov at 2:49 PM 8/16/2005
Modified by dmakarov at 12:16 AM 1/2/2006
from h22 parts
vtec solenoid sold
not oem dual core half size radiator $50 no fan included
bseries side engine mount $30
top engine mount for bseries driver side $35
fan off of 99-00 civic si
types h22 intake cam make offer sold
h22 td61u distributor with external coil comes with the cap
make offer
bseries rear mount $50 sold
upper tranny mount off of b18c $25
lower tranny mount from b18c $40 with vibration mount
h22 fully working with 2 gray plugs td61u stamp on it and comes with stock wires one of them is messed up and have to be replaced $70 obo
commando alarm
never been used but its open everything is new $40
If you still want an H22 head i have one with 50k in MINT* condition... shoot me a pm for details. I am local to you. Puyallup, LMK if u want this thanks. Also if u want pics i can send some pics your way
bump from the dead
still have most of the stuff plus
i got some mint 2000 4dr integra taillights for sale
all 4 pieces
no cracks 120
99-00 ex airbags with module
for 250
01 tan integra airbags with leather wrapped steering wheel for 300
clean set
95 civic black set of airbags with module and sensors
pass and driver no wheel 200
clean set
95 integra tan set of airbags no wheel
comes with driver pass and module
250
one 95 driver integra black airbag 100
2 civic black airbags off of 94 and 92 75 a piece
two black leather wrapped steerings wheels from gsrs 50 a piece
mint
black center console from teg with armrest cloth piece 40 its really clean
set of pr3 rods with ctr pistons
only one piston is good others are beat up
50 for all four come with old bearings and come with rod bolts and nuts
one b16a2 water pump 25 clean
one b16a water pump kind of rusty 15
one b16a main seal
oil pump
crank out of b16a
and one bare block with one tiny crack in cyl 1
oil pan with oil pick up and the cover
45
alternator brackets with bolts
two oil catch cans from b16's
got a 2 sets of b16a3 injectors
one set of ls obd2 injectors and
one set of 99 si injectors and 00 gsr injectors
30 per set
rear kyb gr2 shocks for dc2 or eg blown or something
make offer
one front tokico blue blown
make offer
front shocks from 92 hatch with some kind of springs
stock set of 94 integra springs never been cut
make offer
b16a3 timing belt side bracket and engine mount
make offer
tial green 7 psi spring
rear kyb adjustable shocks red ok condition came off or 92 hatch
rear civic hatch glass
40
pass side glass for eg hatch and one for dc2 teg
all 4 pieces
no cracks 120
for 250
clean set
clean set
250
mint
one b16a main seal
oil pump
crank out of b16a
45
30 per set
make offer
make offer
make offer
make offer
40
