FS: AutoPage RS855LCD alarm pager remote start turbo timer
Old May 18, 2005 | 09:39 PM
braypunt's Avatar
Default FS: AutoPage RS855LCD alarm pager remote start turbo timer
I have a brand new AutoPage RS855LCD alarm. This alarm is similar to the Viper 791XV and Clifford Matrix 3.5 RSX. It features remote start, has a pager and a built in turbo timer. Here are the manufacturer's specs:
STANDARD FEATURES:
* 6 Channel Alarm and Remote Car Starter with 5 on-board relays for parking lights, starter, accessories, ignition 1&2 and one additional relay / socket for starter disable.
* Two-way paging receiver and transmitting remote with 3-color LCD screen using FM frequency bands for transmitting and receiving at 433.9 megahertz. Unit will transmit and receive up to 2000 feet. Unit also includes 24-hour clock with meter minder and temperature indicator and countdown run timer.
* New Molex-plug wiring harness
* Two-way, window mount extended range helical transceiver antenna module.
* One 4-button extended range FM, standard 433.9-megahertz remote transmitter.
* SIS-11 Super Intelligent Sensor with dual stage shock / glass sensitivity.
* Discrete Temperature Sensor that communicates in-car temperature with LCD remote.
* Window-mount Knock Sensor for driver paging.
* Plug-in super bright mini-LED and push-type valet/override switch.
120 dB loud single tone siren.
TWO WAY LCD REMOTE OPERATION:
* 5-button configuration with selectable “Button Lock” to prevent accidental mis-use.
* Uses one AAA type 1.5volt alkaline battery with battery life indicator and power save mode
* 3-color LCD screen displays 29 icons and figures that provide for around-the-clock visual confirmation on vehicle and alarm status. Back lighting for nighttime use. Channels 3,4,5,6 indicators on LCD screen
* Optional Two Car Operation with LCD transmitter only
* Transmits on FM band and receives on FM band.
* 24-hour digital clock with count down timer for parking meter reminder. The clock doubles as a temperature indicator for monitoring in-car temperature. Displays in Fahrenheit or Celsius.
* Multiple audible confirmation tones as well as vibrator mode for paging
* LCD Transmitter Range Check Indicator
ALARM FEATURES:
* Six Channels of outputs (3 dedicated to lock/unlock, trunk and remote start / 3 auxiliary outputs)
* Dedicated function buttons on LCD remote and 4-button standard remote transmitter.
* Code learning / Anti-scan receiver with programmable code hopping.
* Back-up memory system
* Selectable Chirp Confirmation (OEM Style lock only chirp confirmation)
* “Comfort Feature” with OEM systems having key / remote control power window roll-up
* Dedicated remote panic and car locator
* Passive arming by-pass from the remote
* Parking light flash with dual polarity relay on-board
* Plug-in dual stage SIS-11shock sensor with sensor by-pass from the remote
* Starter disable output with relay and socket included
* Dome light illuminated entry output
* Dual polarity (+/-) door lock outputs with optional driver’s door priority two step unlock
* Additional positive and negative inputs
* 500 mA grounded outputs for starter disable and door lock/unlock
* Programmable momentary, latched or timer on 3 auxiliary channels.
* Programmable manual / passive arming with true last door arming with auto re-arm “on”
* Programmable Single / Double Pulse Unlock
* Programmable Parking lights (flash or constant)
* Programmable Pathway Illumination (on / off)
* Programmable voltage sense for delayed dome lights (on / off)
* Programmable horn and siren chirp delete
* Programmable ignition control lock and unlock
* Programmable pulse time for lock and unlock (.9 sec. / 3 sec.)
REMOTE CAR STARTER FEATURES:
* 5 On-Board Relays:
1. Ignition 1
2. Ignition 2
3. Starter
4. Accessory
5. Parking Light
* 3rd Ignition (-) output
* Ground when start (-) output
* New “Turbo Timer” feature
* 2nd Accessory (-) output
* Selectable one or two push “Safety Start”
* Programmable gasoline or diesel with 10, 15, or 20 second “Wait-to-Start”
* Hood pin switch safety input (pin switch included)
* Selectable RPM / Voltage Start
* RPM / Voltage / Hi-Low level check
* Timer control start option
* Sensor control output during start
* Temporary Stop Feature
* Factory Alarm Disarm and Rearm signal output
* Programmable factory keyless door locking before and after start
* Programmable start status output with shock sensor bypass
* 45 second door / dome light bypass after ignition is turned off.
* Programmable Ignition 2 (on / off)
* Programmable 3 hour timer start
* Programmable 1 / 3 hour timer start
* Selectable Run Timer (5/10/20/30 minutes)
* Ignition control by-pass during remote start
* Selectable Gasoline / diesel
* Selectable Diesel warm-up time
* Programmable Ignition control locks bypass (on / off)
It comes with a 1 year warranty.
I am asking $170 shipped for this. Please e-mail me at chrisble233@hotmail.com if you are interested
HMBMotoring
Audio / Security / Video
Oct 20, 2005 01:40 PM
lilmrchillalot
Dec 26, 2004 03:14 PM
