suspension peice ?
well tonight I was working on my car and when I went to put the JDM rear strut tower brace on I broke off on of the bolts off if I am correct this would be a pillow mount bolt that I broke so I need to know where to get a new pillow mount and I would mind buying 4 new ones and I was wondering if it matters what kind they are becuase I have koni yellows on my car so I need some info
Let me throw this in since it's related, hope you don't mind
I overtorqued a front strut mount bolt, and the stud broke off at the base. You are able to see the base of the stud in the wheelwell, but I'm wondering what the best method for removal is. Should I drill it out and just put a bolt in there, or should I hammer it out and put in a new stud (is this even a part?)
Also, are the studs just held in place with that sealant or are they spot welded on?
Thnx.
Thnx.
beepy
Welding / Fabrication
36
Nov 22, 2005 07:23 AM
00WhiteEKy
May 30, 2003 10:09 AM
mmuller
Dec 19, 2002 01:03 PM
