Black Thick Fluid in Clutch Resevoir?
Old May 18, 2005 | 08:35 PM
araknis's Avatar
New User
Default Black Thick Fluid in Clutch Resevoir?
I just noticed that my clutch has no pressure until like 75% depressed so i looked into my clutch resevoir. Inside I saw black thick fluid. My question is how brake fluid gets to this degree?
Old May 18, 2005 | 08:46 PM
cruizinmax's Avatar
Brake fluid absorbs water and it turns black in the process.
Old May 18, 2005 | 09:26 PM
LostGsr's Avatar
Default Re: Black Thick Fluid in Clutch Resevoir? (araknis)
Take a look underneath your dashboard, near your clutch pedal. Is there a leak? The fluid is turning black because one of your seal is getting old. You can try flushing out the old fluild and see if you regain pressure.
Axatax
12
Feb 16, 2013 10:44 PM
superhypie
Aug 30, 2008 05:56 PM
B18Redline
Aug 18, 2003 10:56 AM
Andrew 825SM
May 30, 2003 07:50 PM
ShapeShifterz
Jun 18, 2001 11:12 PM
