Crx Smog Coming up
Old May 18, 2005 | 08:32 PM
91d15bvtec's Avatar
Default Crx Smog Coming up
I was reading a post by superduude about him passing his smog. I have a jdm d15b vtec in my 91 si running off the jdm p08 ecu that was intended to run it. Should i just go to the ref and get it bar certified or should i be able to pull of the under hood inspection with all my stock components(intake, header etc.) thanks for your opinion. Hopefully the test only stations won't care because that is where i have to go.
Thanks
Old May 18, 2005 | 08:42 PM
Gant's Avatar
most likely the smog tech wont really notice, i have a z6 in my car i dont really gotta worry bout it since i can smog it myself but im gonna get it reffed sooner or later
Old May 18, 2005 | 08:59 PM
StorminMatt's Avatar
Default Re: Crx Smog Coming up (91d15bvtec)
You can't go to the ref. This is not a California legal setup. Your only choice is to go to a smog check station and hope they won't notice.
Old May 18, 2005 | 10:37 PM
vw eater's Avatar
Default Re: Crx Smog Coming up (StorminMatt)
is there any way at all to get a b16 to pass smog...? a b16 a1?
Old May 19, 2005 | 04:34 AM
Default Re: Crx Smog Coming up (vw eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vw eater &raquo;</TD></TR><TR><TD CLASS="quote">is there any way at all to get a b16 to pass smog...? a b16 a1?</TD></TR></TABLE>
Yes. The B16A was available here. So a B16A is okay. The only catch is that it MUST run the 1994-1995 USDM Del Sol VTEC intake manifold, ECU, oxygen sensor, distributer, etc.
smelldaOdaa
Mar 25, 2006 04:24 PM
the soL that could
Mar 8, 2006 12:57 PM
FOMULA91
35
Mar 23, 2005 09:31 AM
garrulous thief
Aug 18, 2003 12:45 AM
olddohc
Nov 20, 2002 01:48 PM
