Trying to get started on wire tuck.
Old May 18, 2005 | 07:50 PM
JapJunkie's Avatar
Default Trying to get started on wire tuck.
There was a thread on the removal of the AC which answered some, but not all of my questions, so decided to start my own thread. Also considering that this thread could turn into a very good informative one aswell.
Im a NewB at this wiring stuff, so id figure i would ask you guys on what i can and cannot remove.
I have a 89 Si hb which Im in the process of swaping in a eg sohc dx motor and upgrading to OBD1.
Any info. is appreciated and thanks in advance...here goes...
This is the pass. side front of engine bay by headlight
The relay in the green box is for the headlights right? I know i will be able to tuck that away. I dont know what the relay is for in the yellow box...and can it be removed???
Old May 18, 2005 | 07:53 PM
GroundZer0 336's Avatar
im pretty sure the white box is just grounds. i mounted that inside the fender well when i hid my headlight wires along w/ the bigger box beside it, which is the relay box for headlight/markers.
Old May 18, 2005 | 07:55 PM
JapJunkie's Avatar
Default Re: (GroundZer0 336)
I thought that white box was for the headlights since that exact box is on the other side in the same location by the driver side headlight.
Old May 18, 2005 | 08:06 PM
Joebroni's Avatar
Yeah that white box is just a housing for most of all of the lights. The relay beside it is for the radiator fan. Both can be relocated, mine are almost directly behind my blinker. I had to extend almost every wire.
Old May 19, 2005 | 10:28 PM
jdmEFsedan's Avatar
Default Re: (Joebroni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joebroni &raquo;</TD></TR><TR><TD CLASS="quote">Yeah that white box is just a housing for most of all of the lights. The relay beside it is for the radiator fan. Both can be relocated, mine are almost directly behind my blinker. I had to extend almost every wire.</TD></TR></TABLE>
Yeah..that's right...the white box is the ground for most of the front "stuff" and the one beside it is for the fan. I actually relocated most of the grounds inside the cabin as well as that relay. All in all...wire tucking an EF isn't too bad. For an even cleaner look, relocate the Fuse box. There are a couple helpful threads on this...I remember a white CRX and a red Hatch that did this. My thread in my sig also has some pics of how I did mine...check it out. I believe the pics are on page 3.
I'll try to find the creators of the other threads, too.
Old May 20, 2005 | 04:44 AM
civhatch90's Avatar
i think it is this which is relays for air conditioning, at least on my car. try following the wires and see were they lead u
Old May 20, 2005 | 07:11 AM
jdmEFsedan's Avatar
Default Re: (civhatch90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civhatch90 &raquo;</TD></TR><TR><TD CLASS="quote">
i think it is this which is relays for air conditioning, at least on my car. try following the wires and see were they lead u</TD></TR></TABLE>
Yup, those are for the air conditioning...and if you do remonve the a/c...these get remonved as well.
Old May 20, 2005 | 08:26 AM
JapJunkie's Avatar
Default Re: (jdmefsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmefsedan &raquo;</TD></TR><TR><TD CLASS="quote">
Yup, those are for the air conditioning...and if you do remonve the a/c...these get remonved as well.</TD></TR></TABLE>
w3rd, i just removed mine
Old May 20, 2005 | 08:54 AM
JapJunkie's Avatar
Default Re: (JapJunkie)
So when i was ripping out wat i thought was the AC wiring...I found out I didnt know which plug was for my cooling fan...
Is it this white plug(I hope) or was it the green plug from this harness i pulled out?
Old May 20, 2005 | 09:58 AM
crxgator's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">green plug is radiator fan. keep that in.</TD></TR></TABLE>
one is for the regular fan and one for the a/c i thought? i forget, i know i took out the plug for the a/c fan...iirc it was part of the a/c harnless like he took out?
Old May 20, 2005 | 10:43 AM
crxgator's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">i mean to keep the harness wit hthe green plug. the white plug is to the AC fan, remove that and the accompanying harness.
if theyre joined together, which i dont remember them being, just separate them.
green = radiator. keep.</TD></TR></TABLE>
alright...
Old May 20, 2005 | 12:56 PM
Tyson's Avatar
Default Re: (crxgator)
holy crap, im wrong!
green is NOT the radiator plug. the bigger, (female?) harness side of the radiator fan is green, but the electrical harness plug is not green.
BOTH plugs for the AC harness are green for each plug.
my apologies.
so yeah, thats an AC harness probably, but still dont cut anything. just remove it completely.
Old May 20, 2005 | 02:08 PM
JapJunkie's Avatar
Default Re: (Tyson)
To make things clear, the white plug is for the radiator fan.
Old May 20, 2005 | 02:15 PM
Tyson's Avatar
yeah, sorry for the confusion. i double checked with my car.
this is the radiator plug. what this goes into is green however. but it looked like all the AC plugs were green too.
Old May 20, 2005 | 04:57 PM
superhatchbackbros's Avatar
i took them relays out and followed the wire back to the fuse box under the hood i took out the white clip that went next to the (2) 15amp fuses now it goes into the fire wall into a gromet ----- do i cut it or where does it lead to to unplug it ??? -------and takin out them relays near the batt and headligh wont mess anything up
Old May 20, 2005 | 06:32 PM
Old May 20, 2005 | 06:54 PM
Magick211's Avatar
Default Re: (superhatchbackbros)
I have the headlight ground boxes mounted inside the car
Old May 20, 2005 | 09:19 PM
jdmEFsedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superhatchbackbros &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
If you follow the wire inside the cabin, you'll find out where to disconnect it. it should be located around the ecu area.
As for the two clear looking boxes on each side of the car, those are grounds. SO...just as long as all the grounds are connected somewhere on the car that's metal, you'll be fine.
Now, for the fan relay and other wires...
I relocated the fan relay inside the car and ran the fan wires out of the side of the car (there's a hole under the dash by the kick panels), along the inner upper frame rails (the rails that support the fenders), and through the holes located in the front of them. I used the same route for the headlights, signals, horn, corner lights, etc. The grounds do not necessarily need to follow the same route. Just as long as you hook up the grounds to metal, you'll be fine.
Check out my thread in my sig...there are pics there on page 3!!
Hope this helps.
Old May 21, 2005 | 03:44 PM
JapJunkie's Avatar
Good info.
Old May 22, 2005 | 11:44 AM
craiger's Avatar
when u removed this and all the wiring which i believe is like red blue yellow wires...did u cut them at the firewall cause i cant find where they go to when i get to where my ecu is i even took off my glove campartment please let me no how u removed that
Old May 22, 2005 | 12:02 PM
kid-crx's Avatar
up
Old May 22, 2005 | 01:09 PM
RCautoworks's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">holy crap, im wrong!
Your not wrong really.
I have looked at 3 crx's and 1 hatch.
2 of the crx used green/green plugs, the hatch and the other crx both used white/green
Old May 22, 2005 | 02:52 PM
kid-crx's Avatar
please someone answer my question
Old May 22, 2005 | 04:20 PM
crxgator's Avatar
Default Re: (supportRhondas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supportRhondas &raquo;</TD></TR><TR><TD CLASS="quote">please someone answer my question</TD></TR></TABLE>
what question?
Old May 22, 2005 | 06:54 PM
kid-crx's Avatar
the question about how i should get ride of those wires i posted the pic like 5 or 6 posts up look its there
