Accord backfires and hesitation plz help
I have a 93 honda accord with the f22b jdm engine in it and i need some help my car runs fine at low rpms yet when i smash the pedal and at full throttle the car begins to backfire and hesitate at 5.5 to 7 rpms what could this be i changed cap, rotor, plugs, and pcv. I dont know what it could be? some people tell me that it is egr valve or tps sensor? has any one had any of these promblems before in the past pleaze help, help much appreciated.
Most probably running to rich. I would do the following:
1. check coolant temp sensor
2. check O2 sensor
3. inspect catalytic converter
4. check diverter valve and vacuum leak
Might also do a compression check to make sure...
fs
2. check O2 sensor
fs
DNGUYEN1904
Oct 9, 2018 07:44 PM
