injector question
well i read up about injectors... and i know the amount of horsepower you have depends on the XXXcc injector you use for your motor, turbo motors half to use a bigger injector because they burn more fuel. correct? well my question is, for a 200hp gsr, the correct injector size you should use is 370cc (going by the equation rc engineering has given me.) http://www.rceng.com/technical.htm why do ppl use 440cc injectors on a motor that doesnt peak 180hp to the wheels, is it just better to have more fuel going into your engine when its not needed. im still confused, can someone enlighten me.
