98 + gsr cams have a different lift than 95 gsr cams?
Old May 18, 2005 | 05:20 PM
Bay_707's Avatar
Default 98 + gsr cams have a different lift than 95 gsr cams?
someone told me they are different like they have a different lift is this true?
Old May 18, 2005 | 05:37 PM
gsrious's Avatar
Default Re: 98 + gsr cams have a different lift than 95 gsr cams? (Bay_707)
i believe only the 00-01 have the higher lift but less duration...
**don't quote me on that**
Old May 18, 2005 | 05:46 PM
PDM's Avatar
PDM
Default Re: 98 + gsr cams have a different lift than 95 gsr cams? (red dc2)
STOCK GSR : b17a and b18c1 (Chilled Cast Core)
INTAKE lift - 10.6 mm,duration - 230 @1mm
EXHAUST lift - 9.4mm, duration - 227@1mm
They are the same. The Type R changed specs 00-01 from 98-99. The GSR has remained the same. B16A2/3 also run on the same specs as the GSR
austrian type-R
Jun 6, 2003 05:49 AM
brent_G
Sep 27, 2002 07:43 AM
