Prelude SI with H22 motor, what cat to use?
Doing the H22 swap on the SI right now, and I don't know if the SI cat will fit the h22 downpipe. Will they bolt up or should I look for the h22 cat? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtremeSpeed »</TD></TR><TR><TD CLASS="quote"> yeah i was wondering that too. when i do my swap, i can just use my H23 cat and full exhaust, </TD></TR></TABLE>
This is what I am doing, yes you can.
and when i switch to my VTEC thermal exhaust i just need to use a h22 cat right? </TD></TR></TABLE>
I would think so, although I thought all 92-96 Si and VTEC model aftermarket exhausts were the same part # from any given company.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PreludeSi »</TD></TR><TR><TD CLASS="quote">
I would think so, although I thought all 92-96 Si and VTEC model aftermarket exhausts were the same part # from any given company. </TD></TR></TABLE>
They are and the cats are the same aslo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec »</TD></TR><TR><TD CLASS="quote">They are and the cats are the same aslo
The 96 model year cats are not the same. 92-95 are all the same, the 96 cats have the secondary O2 bung. You can use a 96 cat in the 92-95 cars if you plug the extra bung with a spark plug, but you can't use a 92-95 cat in a 96 unless you drill and weld in another bung, which is a LOT of work......
Also, FYI, for you people with 96's who sold yours and now need a cat for emissions and have realized that 96 prelude cats are impossible to find, you can use a 5th gen cat. It'll bolt to the downpipe fine (bolt pattern is the same) but the pattern to the mid-pipe is slightly different (the 5th gen cat bolts are spaced slightly closer together). If you enlarge the holes on the mid-pipe .5 cm larger towards the inside, everything will bolt up fine.
</TD></TR></TABLE>The 96 model year cats are not the same. 92-95 are all the same, the 96 cats have the secondary O2 bung. You can use a 96 cat in the 92-95 cars if you plug the extra bung with a spark plug, but you can't use a 92-95 cat in a 96 unless you drill and weld in another bung, which is a LOT of work......
jaysome01
May 12, 2009 08:34 AM
Knightmare69
Mar 14, 2006 12:49 PM
crdcz03
Feb 21, 2006 08:03 AM
