identify flywheel help!
i purchased a jdm h22 motor that came with a flywheel so i went to go put a act clutch on and the spindles didnt line up. i then got a flywheel from a buddy of mines and it fit perfect. on the back of the flywheel they had some stamped codes cant anyon tell me where this flywheel is from? here are the numbers. says from top to bottom OE,AG left to right U1, 21
are you sure you put the pressure plate on correct.? they only go on <U>one</U> way..
as for the numbers i don't noe.. me so solly , haven't touched a h-motor yet.
only b's
only b's
meltSolid
Dec 3, 2002 11:33 PM
