Build Up Advice?
OK... Im new to the forums here and I was hoping you guys could give me some advice. I've been planning on starting a new project soon and what I want to do is build up a motor. Ive only ever done rebuilds on Chevy 350's and ive done alot of maintanace on just about anything else. What I want to do is just put a motor on a stand and after about 7 or 8 months of tinkering, put it in a car. I dont really want to spend alot of money on the motor itself so i was originally thinking of rebuilding a gen 2 b16a with alot of performance internals. After doing alot of reading on the b16a and vtech and whatnot ive actually grown slightly afraid of vtech. Dont get me wrong i really want it but im not so sure i really want to be tinkering around too muich with the electronic side of a motor. After alot of thinking ive been leaning toward a gen 2 b18b non vtech. Since its going to be all motor i want to put in most of the following....
- cams
- header
- intake manifold
- bigger throttlebody
- pistons
- valves
- springs and retainers
- do a port and polish
- upgrad all the ignition parts
- and maybe get the head decked while i get the port and polish done
Theres probably going to be alot more things i need but thats just the basics. Is there any advice you guys give me or maybe even suggest a different motor. Im more familiar with volkswagens than hondas so a little help would be greatly appreciated.
thanks,
eric
- cams
- header
- intake manifold
- pistons
- valves
thanks,
eric
What kind of car are you planning on putting this motor into, is the electrical part you talking about having to wire up VTEC in to a non-vtec chasis, cause that is easily fixed, you just have to go to like http://www.hasport.com and buy a wire harness, that will easily fix any problem you might have wiring. VTEC motors prodecue more horsepower but less torque than an non-VTEC motor, there are advantages and disadvantages to both. You also said though too that $$$ is a concern for you, if you want to build a good set up I say build a LS/VTEC motor which is using a block from a non-VTEC Acura so like a B18B block and then get a VTEC head like from a B16 or a B18, if you do a search you will find many people talking about LS/VTEC motors in here. Good luck though with whatever you decide on.
The original plan is to put it into a 88-91 civic hatch but im having a hard time loacating one thats not really rotted. I kinda like the idea of the final product being a built up non vtech and leaving it non vtech but im still thinking about it. What do you think a fairly built up non vtech can throw down?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eric_Hayward »</TD></TR><TR><TD CLASS="quote">The original plan is to put it into a 88-91 civic hatch but im having a hard time loacating one thats not really rotted. I kinda like the idea of the final product being a built up non vtech and leaving it non vtech but im still thinking about it. What do you think a fairly built up non vtech can throw down?</TD></TR></TABLE>
go to http://www.nonvtec.com and a streetable ls can throw down 170-180 whp with out to much trouble
ravs
Sep 8, 2007 10:29 AM
