Which tires are batter Falken Ziex Ze-512 vs. fuzion ZRi? for daily drive
Old May 18, 2005 | 02:38 PM
Jaydeep's Avatar
Default Which tires are batter Falken Ziex Ze-512 vs. fuzion ZRi? for daily drive
I need 205-45-16 size tires for my rota rims. Which tires are batter Falken Ziex Ze-512 vs. fuzion ZRi? only forsummer daily drive?
I need tires that last me long since I am not going to race.
Old May 19, 2005 | 04:48 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: Which tires are batter Falken Ziex Ze-512 vs. fuzion ZRi? for daily drive (Jaydeep)
I have never heard of "fuzion ZRi" but I have Ziex 512's on my daily driver EP3, and I can certainly testify that they are a lot of tyre for the money.
They seem to handle all temperatures very well, and handle wet weather very well.
I think I have about 30,000 on mine, and it looks like they're going to last a while longer.
Old May 19, 2005 | 06:36 AM
Jaydeep's Avatar
Default Re: Which tires are batter Falken Ziex Ze-512 vs. fuzion ZRi? for daily drive (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">I have never heard of "fuzion ZRi" but I have Ziex 512's on my daily driver EP3, and I can certainly testify that they are a lot of tyre for the money.
I think I have about 30,000 on mine, and it looks like they're going to last a while longer. </TD></TR></TABLE>
Fuzion ZRi are new in market made by brigestone. Did any one had experince with both tires?
Old May 19, 2005 | 10:41 AM
SMZ GSR's Avatar
If you just want a tire to commute on, get the Ziex. The Fuzion is a good tire, but the Ziex will last you longer and are cheaper.
Old May 19, 2005 | 01:59 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaydeep &raquo;</TD></TR><TR><TD CLASS="quote">I need 205-45-16 size tires for my rota rims. Which tires are batter Falken Ziex Ze-512 vs. fuzion ZRi? only forsummer daily drive?</TD></TR></TABLE>
The ZE-512 is an all-season tire, which means that it's designed to perform okay at a wide range of temperatures, including okay grip in frigid temps and snow as well as warmer weather. All season tires tend to be okay in warm temps but not as good as summer tires, and okay in very cold temps but not as good as winter tires.
If you're not planning on using them in the winter, I would get the Fuzion ZRi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">I have never heard of "fuzion ZRi"</TD></TR></TABLE>
Fuzion is a new brand created by Bridgestone for the marketing of tires to the tuner crowd. Its ZRi model tire is a "bang for the buck" budget performance tire in the same class as the Yokohama AVS ES100. The ZRi did very well against the ES100 in a side-by-side comparison test conducted by the Tire Rack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMZ GSR &raquo;</TD></TR><TR><TD CLASS="quote">the Ziex will last you longer and are cheaper.</TD></TR></TABLE>
There's no way for you (or anyone else) to know how many miles the ZRi will last, because it's brand new to the market and no one around here has worn out a set.
The difference in cost is only $9 per tire. Again, if you're not planning to use it in winter, I would get the ZRi. If you're looking for an all-season tire for occasional winter use, then the ZE-512 is worth considering.
Old May 19, 2005 | 02:53 PM
JFP's Avatar
JFP
Default Re: Which tires are batter Falken Ziex Ze-512 vs. fuzion ZRi? for daily drive (SMZ GSR)
Falken Ziex 512 ..
Old May 20, 2005 | 06:53 AM
Jaydeep's Avatar
Default Re: Which tires are batter Falken Ziex Ze-512 vs. fuzion ZRi? for daily drive (nsxtasy)
Thanks for your help
I saw the review for Fuzion ZRi at Tirerack.com but I could not find any reviews for Falken Ziex 512.
Does anyone know where to find Falken Ziex 512 review?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">The ZE-512 is an all-season tire, which means that it's designed to perform okay at a wide range of temperatures, including okay grip in frigid temps and snow as well as warmer weather. All season tires tend to be okay in warm temps but not as good as summer tires, and okay in very cold temps but not as good as winter tires.
The difference in cost is only $9 per tire. Again, if you're not planning to use it in winter, I would get the ZRi. If you're looking for an all-season tire for occasional winter use, then the ZE-512 is worth considering.</TD></TR></TABLE>
Old May 20, 2005 | 10:03 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaydeep &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know where to find Falken Ziex 512 review?
No, but I can certainly give you my own favourable one.
slammedteg23
May 17, 2009 11:34 AM
hondajustin
Apr 21, 2008 02:35 PM
Jaydeep
13
May 20, 2005 02:11 PM
systemoverload
13
Dec 29, 2004 08:22 PM
Mr.E.G.
13
Mar 24, 2004 02:08 PM
