Turbo Car and Carbon Fiber Hood
I have a 99 Turbo'd Ls and I'm planning on putting a CF Hood on. What will happen to the hood if anything (with the little extra heat)? Is there a way to protect it?
i have never had any problems with mine. i had a ls/vtec turbo and and its sets up a little higher than a ls. and with the mani i had i never had any problem's............wear it out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus »</TD></TR><TR><TD CLASS="quote">buy a cf hood with vents over the turbo and wastegate</TD></TR></TABLE>
I just sold my vented cf hood
for an oem one. It does help to let out heat from the turbo/mani but so far so good with my new oem cf hood. Should be just fine, many cars running oem cf hoods with boost.
If you're looking to protect a hood (C/F or otherwise) from radiant heat, you could try something such as this: http://www.jegs.com/cgi-bin/nc...r=361
Whether or not it's actually necessary will depend upon the type and quality of the hood, the amount of heat your setup generates, and the proximity of the turbo components to the hood itself.
mine is doing fine and i live in socal. i might be putting washers between the nuts that hold the hood down near the windshield. a hot rod style. it seems it would give me better cooling.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls InTeGrA RaCeR »</TD></TR><TR><TD CLASS="quote">hood prop? you mean pop the hood?</TD></TR></TABLE>
I believe he's referring to shimming the rear of the hood to raise it slightly. The most common way that people do this is to place washers or some other inexpensive form of spacer between the hinges and the hood itself, in an effort to improve under-hood ventilation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">I believe he's referring to shimming the rear of the hood to raise it slightly. The most common way that people do this is to place washers or some other inexpensive form of spacer between the hinges and the hood itself, in an effort to improve under-hood ventilation. </TD></TR></TABLE>
youll need longer bolts as well
should only be like $1 to do everything.lol
daidilus is my good friend my name is reflex da techstepa i have 97dc2 started as an ls
it was a type r for a while trade my motor to my shop for a fully tuned gsr everything was done to this motor it was a dragster motor and i have a fiber images cf hood oem style and it has started to crack over the turbo and heat wraping works but i dont use it i have heard it can crack headers
scooter
Jul 16, 2003 03:46 PM
GraphiteAccord
May 5, 2003 12:00 PM
