Parts needs to install ITR lip.???
Old Feb 5, 2002 | 03:54 PM
rsx03's Avatar
Default Parts needs to install ITR lip.???
Guys,
do any of you have the appropriate part #'s for what is need so that I can order & install the Type-R lip spoiler onto my car???
Also, if you have a copy of the installation instruction sheet in .PDF format that would appreciated..
Thanks!
Old Feb 5, 2002 | 04:03 PM
STOLEN - ITR 98-0652's Avatar
Default Re: Parts needs to install ITR lip.??? (2K1GSRBOY)
Lip, ITR. or Lip, OEM Body Kit (same/same).
Screws (philips). Quantity: 8 or so... (check the Helms)
Screwdriver (philips).
Old Feb 5, 2002 | 04:12 PM
ThePunk's Avatar
Default Re: Parts needs to install ITR lip.??? (ITR 98-0652)
The ITR lip/OEM underbody kit lip, *Should* come with all the required hardware from the dealership. There are some unusual fasteners that are used when installing it, IE the Nut inserts for the outer edges, and the captive nuts for along the bottom/in the wheel well.
Old Feb 5, 2002 | 04:33 PM
junglistgsr's Avatar
Default Re: Parts needs to install ITR lip.??? (ThePunk)
it comes with clips that slide in onto the stock bumper which you then screw in some bolts that also come with it and then there are screws that you need to use as well that come with it.....installation is easy as **** and is self-explanatory once you get on the ground and look at under the bumper and the lip itself and see the points where they bolt up.
Old Feb 5, 2002 | 05:24 PM
rsx03's Avatar
Thanks for all the comments guys, but because I bought this ITR lip off a private seller. he has no fastner hardware for it and therefore I need to go and get them, but I need all the part #'s for them..
Please anyone have them or can get them for me and just list them in this thread.
Old Feb 5, 2002 | 05:32 PM
ThePunk's Avatar
Go to acura, the parts department can set you up with what you need.
Samuels
May 11, 2008 11:28 AM
rawNArsxS
May 8, 2008 02:17 PM
sittingonROTAS
Sep 17, 2005 07:11 PM
stumpyf4
Jan 7, 2004 07:06 PM
integranator
Dec 9, 2002 06:47 AM
