Question about rear hubs....
I'm in the middle of installing my rear brake conversion, but noticed that one of the rear hub bearings are shot. I've come to a conclusion that I DO need to get an entire hub assembly
Anyways, here's my question....
I have the rear trailing arms from a 95' GSR with ABS, I noticed that the 99-00 Si' (without ABS) hubs are cheaper by $30ea. I cannot make use of the ABS anyways, does anyone know if it is possible to use the NON-ABS hub on the trailing arms from an ABS car?
Here is some useful information I found out as I was searching around....
1. Honda Civic 99-00 Si Front Bearings are the same as GSR front bearings
2. Honda Civic 99-00 Si front lower ball joints are the same as the GSRs
3. The ABS version of the rear hub is the same between Integras & Civics with ABS and rear disks
(This is all done by comparing part #s)
I've heard that all rear disc assemblies are the same..........
Not sure about abs to non-abs though, just trying to help.
EDIT: All civic and integra rear discs......... excuse me.
Only difference is there is no gearing on the hub of non abs parts.
Bearings themselves are the same.
Ive found that a lot of parts, that are the same, between honda and acura cannot always be proven the same w/ part #s.
JDMCRX
May 28, 2008 06:45 PM
