My suspension SetUP
Old May 18, 2005 | 11:01 AM
DreamCatcher's Avatar
Default My suspension SetUP
Please give me your opinion on my proposed suspension setup.
1.) Tein Super Street Damper Kit w/ Pillow Ball Mounts
2.) Eibach Anti-Roll-Kit 88-91 Civic/CRX Bar 22mm-F/22mm-R
3.) Brakes will be upgraded rear will be upgraded from drums...front will receive larger rotors/quality pads.
I purposely left out things such as upper strut bars: there is to much confusion over there usefulness. About sways, I enjoy the idea of the anti-roll funtion of sways, but do not want to go too big in the rear. I don't have any experience with handling cars with oversteer. I don't just want a good handling car, but one that (I) can handle. Would the 22mm front and 22 rear configuration give positive results (in theory) Should I go slighty bigger in the rear.
GOAL: a car that handles well on both the back rural roads and empty curvy late night streets that I frequent.
CAR: 91 crx dx
Old May 18, 2005 | 11:37 AM
bc_ef8's Avatar
Is the Eibach rear sway adjustable?
I'm running Suspension Techniques sway bars, also 22mm front and rear but the rear is adjustable. I have it on the stiffest setting right now and the car rotates pretty good but not to the point where you lose it under throttle.
Old May 18, 2005 | 12:53 PM
They are not adjustable. I might check out susp' tech' sway.
Old May 18, 2005 | 03:35 PM
FalkenSiR's Avatar
Default Re: (DreamCatcher)
Yea they are not. However, you can get them in different thicknesses.
I have been drooling over that eibach anti-roll kit for a while
bobby_da6
Sep 10, 2008 05:23 PM
Coolcat55
24
Mar 30, 2007 05:44 PM
NTGR8D
Mar 7, 2005 09:17 PM
civais
Feb 23, 2005 06:18 AM
