drag raced my car for the first time
Old May 18, 2005 | 09:26 AM
92 CIVIC HATCH VX's Avatar
Default drag raced my car for the first time
My car is slow........? maybe not it's just me and my driving.
1994 vx hatch with h22a
fluidyne radiator
autozone intake
prospeed header
clutch masters stage 1
apexi n1 exaust
full interior
CEL for o2 sensor because there is a staight pipe running instead of the cat.<maybe>i'm running rich or lean because of this? i don't know
Car is not loud at all on things loud is the motor when floored
140lbs passanger
and a full tank of gas
i have BF goodrich T/A dragradials on
launched @ 3500 <maybe a higher launch?>
my friends 2000 si
gutted
1/4 of a tank of gas
autozone intake
greddy exaust
ran 15.7 pealing out through 3rd last year at the track
due to suspension and shitty tires
he stayed nose to nose till 3rd gear the i leaped ahead 1/2 a car
i heared the h22 in a eg is going to rund l0w 14's to like 13.9 in the quater?
is it my launch?
the engine has 100k on it and has 150-155 compression across
engine's has not been changed in about 5-7000 i bought the car last week.
i have these part to install and thing's to do the battle of the import is in september
and if i can't low 12's by then i'm going to be pissed.
Aem ems and tuning this weekend
l-cons traction bar
skunk2 900lbs rear springs
new j-racing whale ***** intake
Amsoil oil change <im going to run a diffrent brand for 1/2 day with some engine gunk remover so i can get the sludge out before i put the ams in>
NGK v-power plugs
and gut the interior.
turbo charging during the winter
PLEASE ANY HELP AND SUGGESTION ON WHY OR WHAT ELSE IS NEED FOR MY GOAL
<PRACTICE I ALREADY KNOW>
Modified by 92 CIVIC HATCH VX at 8:36 PM 5/18/2005
Modified by 92 CIVIC HATCH VX at 5:30 PM 5/20/2005
Old May 18, 2005 | 09:32 AM
CompressionFed's Avatar
Default Re: drag raced my car for the first time (92 CIVIC HATCH VX)
So what did you run? 15.7 or was that your friend? Low 12's is not going to happen until you build the engine a little more. The EMS is a nice add on though.
You are correct, most h22 hatches run high 13's low 14's.
Old May 18, 2005 | 09:44 AM
Default Re: drag raced my car for the first time (CompressionFed)
we did it on a empty deserted side road.
so i don't know the time, until in about two weeks but he will have his type-r header replica and catco cat and jackson racing super charger on. damn him
Old May 18, 2005 | 09:46 AM
but if i raise his compression 2 lets say 45-50 psi i might have a chance...........oh yeah
my compression was 21 psi on the bfg's
Did you leave your engine OBD1? If so, your straight pipe should not leave a CEL. You probably don't have the O2 sensor wired correct. Check that out.
Old May 18, 2005 | 09:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX &raquo;</TD></TR><TR><TD CLASS="quote">but if i raise his compression 2 lets say 45-50 psi i might have a chance...........oh yeah
my compression was 21 psi on the bfg's</TD></TR></TABLE>
What? Do you mean air pressure in the tires?
Old May 18, 2005 | 09:50 AM
yes air pressure in the tires
Old May 18, 2005 | 09:51 AM
yes engine is obd 1 there is a o2 bung in the prospeed but it's not hooked up to anything?
the cell comes on after about 3-5 mins of driving the aem tuners in town said they can eliminate that when i hook up my aem ems and dyno tune.
i'm going get a dyno reading before and after the hook up of the aem ems to compare results
Old May 18, 2005 | 12:31 PM
looking down at my exaust and how many o2 sensors or there on the h22 piping?
i only have one?
Old May 18, 2005 | 12:42 PM
If your wiring was OBD2, the computer would be looking for a second o2 reading. If you had a straight pipe in this situation, the two o2 sesors would read the same, making the computer throw a code. The reason is, on OBD2 cars, there is one o2 before the cat, and one after the cat. The cat acutally breaks down the emissions and by the time your exhaust reaches the second o2 reads lower.
Since you are wired OBD1, you only need one o2 sensor. If you are still shooting a CEL, either the sensor is bad, or you wired it up wrong.
Did you use the o2 that came with the car, or the one that came on the motor?
Old May 18, 2005 | 12:54 PM
? nu image in kansas did the install for the guy i bought the car off of i've only had it a little over a week.
i will have them check saturday on the cel.
would it be making car run lean or rich?
Old May 18, 2005 | 07:35 PM
just bought some NGK 8mm wires nology doesn't seem right for the price.
these will work just fine.
what should i gap my plugs at there at .40mm right now.
Old May 19, 2005 | 06:21 AM
The car should run rich if your o2 is bad. Leave the plugs where their at.
Old May 19, 2005 | 07:58 PM
if the usps deliver the EMS i can get that tuning done and if the o2's bad then i need to replace soon
Old May 20, 2005 | 01:59 PM
djmota's Avatar
my 2001 civic 2dr does 15.7 with no passenger seat all motor D17 . your friend needs some tires. If you are running drag radials set the psi to around 18lbs and launch at a higher rpm.
Old May 20, 2005 | 02:18 PM
TurboLude97's Avatar
Default Re: drag raced my car for the first time (djmota)
are you sure your compression #'s are right? cuz even w/ 9:1 pistons im getting ~ 180 and my bro w/ 11:1 is getting ~210 yours seems low
Old May 20, 2005 | 04:29 PM
Default Re: drag raced my car for the first time (TurboLude97)
it has 100k on the motor
but it's a cheap compression tester so give or take 10 psi
EM-One
Jun 28, 2007 02:15 PM
VTEC_PRODUCTION
Mar 29, 2007 07:39 AM
92 CIVIC HATCH VX
May 8, 2005 07:58 PM
JDMs1eeper
Jun 22, 2004 12:35 PM
boosted97
Jun 30, 2001 08:43 PM
