oil leak fixed. now blowing smoke?
Old May 18, 2005 | 08:37 AM
99jdem18L's Avatar
Default oil leak fixed. now blowing smoke?
last week i had a problem with an oil leak i lost alot of oil fast when i was driving and once i noticed it i put opil in my car so i could drive it home. Once i got home i realized the leak was coming from my oil sending unit that i had from autometer that worked with my oil pressure gauge. i replaced the sending unit with the OEM piece now the leak is fixed, but my car is feeling alittle sluggish and when i start my car it smokes as i drive away then if i enter into vtec i get another cloud of smoke. Anyone know what this could be. thanks
99civic si w/
1997 b18c1
Old May 18, 2005 | 11:25 AM
. o 69 o .'s Avatar
Default Re: oil leak fixed. now blowing smoke? (99jdem18L)
--is there anything strange looking in your coolant?
--If you take off the oil cap, its there a whitish residue in the motor and on the cap?
--pull out the spark plugs and mark what cylinders they were in. what colour are they? any strange looking wear on them?
--check your compression
--check your timing
-- Are you getting any CEL's?
Old May 18, 2005 | 12:04 PM
LSVTEC 91 Civic's Avatar
Banned
If you ran the car low on oil you could have screwed something up, I suggest you do what B16B said.
Old May 18, 2005 | 05:30 PM
99jdem18L's Avatar
Default Re: oil leak fixed. now blowing smoke? (B16B)
-no whitesh residue
-no check engine light
what do i need to buy to be able to check my compression? i will check the coolant,plugs and timing tomarrow thanks alot b16b!!!!
thisoneroller
Honda Civic (2006 - 2015)
Feb 22, 2011 07:15 AM
ringgold
Sep 17, 2006 10:51 AM
AntMan401
Aug 23, 2006 09:38 AM
peel17
Feb 1, 2005 11:28 AM
itsJDMyo
10
Aug 26, 2004 12:16 PM
