What steering part to buy to solve my problem?! Pic/Searched
Old May 17, 2005 | 09:37 PM
FalkenSiR's Avatar
Default What steering part to buy to solve my problem?! Pic/Searched
My problem is, if I go anything faster than 50 mph, my steering wheel (and the whole car for that matter) starts to shake. It's like there's something loose in the right side. So far I have replaced: Both Tie rod ends(25, 26, 27 -for both sides- in pic) and Right Lower Ball joint (suspension). Same thing. These parts were shot anyways so at some point I had to replace them.
According to what I found, Inner tie rod end (part 20) looks the most suspicious to me. I read in several threads that Part 10 could cause this also. Now, is the inner tie rod end (#20) attached to part 10 or is it way inside the rack? If this is too hard, then I'll have a shop do it. I'm giving up... one problem after another in this car...
Also would you recommend getting the inner tie rod end while I'm at it? Only if necessary tho...
Old May 17, 2005 | 10:05 PM
FalkenSiR's Avatar
Default Re: What steering part to buy to solve my problem?! Pic/Searched (fast88std)
Also, would item #21 (lock washer) come with the inner tie rod end if I get it?
Old May 18, 2005 | 01:36 AM
limpy's Avatar
try an alingment 1st
Old May 18, 2005 | 03:41 AM
chickenandpickles's Avatar
simply sounds like your front and/or rear wheels need to be rebalanced...
Old May 18, 2005 | 09:11 AM
FalkenSiR's Avatar
Default Re: (chickenandpickles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chickenandpickles &raquo;</TD></TR><TR><TD CLASS="quote">simply sounds like your front and/or rear wheels need to be rebalanced...</TD></TR></TABLE>
Done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpy &raquo;</TD></TR><TR><TD CLASS="quote">try an alingment 1st</TD></TR></TABLE>
This is not something that could be caused by an bad alignment, but for worn out suspension parts.
Old May 18, 2005 | 02:19 PM
FalkenSiR's Avatar
Default Re: (fast88std)
bump
Old May 18, 2005 | 02:40 PM
ALX's Avatar
ALX
have you checked the wheel bearings?
Old May 18, 2005 | 02:51 PM
FalkenSiR's Avatar
Default Re: (ALX)
They are fine. You can tell that there's something loose, plus I have vertical play in the right tie rod. Very slight, but I think that makes this vibration.
Old May 18, 2005 | 03:44 PM
BCrawford's Avatar
Why can't the alignment play a part in your vibration?? That's what it sounds like. My car does the same thing, but it was a lot worse b4 new tie rods and balanced wheels. I need alignment too.
Old May 18, 2005 | 03:45 PM
xci_ed6's Avatar
get an alignment, it could be insufficient caster. if it is the tie rods, they will tell you when they do the alignment.
Old May 18, 2005 | 03:54 PM
24TEN's Avatar
PHANTOM MENACE
does it get worse if you apply the brakes? if it does, it could be that your disc(s) are warped. just a thought. i've had the same issue with my car once and that was the problem.
Old May 18, 2005 | 05:50 PM
green91's Avatar
caster is not adjustable in our cars. the tie-rod should rotate slightly due the ball joint movement, but any other movement is bad. a bad alignment will not cause vibration
Old May 18, 2005 | 06:20 PM
FalkenSiR's Avatar
Default Re: (green91)
I was talking with my dad and I'm starting to consider an alignment. I noticed I have positive toe on my right wheel (ver visible outwards). I'll try that I guess.
Old May 18, 2005 | 08:49 PM
.Unknown.'s Avatar
I agree Alignment.
Old May 18, 2005 | 10:16 PM
*Boostwerks*'s Avatar
I would definetly say get an alignment first, and then if you still have problems something needs replacing.
My hatch also does this, but only past 65mph. I've had the wheels balanced, and I've even had an alignment. Most like one of the wheels is flat spotted or one of the stock 13" rims is bent.
Old May 18, 2005 | 10:32 PM
l e o h j's Avatar
did u check your tires?
sometimes your tire has a bump inside that causes the shaking..
i dunno, that was my problem before when i was going above 50-60mph it starts to shake and wiggle.
Old May 18, 2005 | 10:39 PM
xci_ed6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 &raquo;</TD></TR><TR><TD CLASS="quote">caster is not adjustable in our cars. the tie-rod should rotate slightly due the ball joint movement, but any other movement is bad. a bad alignment will not cause vibration</TD></TR></TABLE>
sure it is, a curb and some speed will set it right outside of factory recomended specs.
Old May 18, 2005 | 10:52 PM
Default Re: (krustindumm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">
sure it is, a curb and some speed will set it right outside of factory recomended specs.</TD></TR></TABLE>
lol...or traction bars....if you want to go with the safer, more down to earth approach.
Old May 19, 2005 | 08:10 PM
xci_ed6's Avatar
Default Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">lol...or traction bars....if you want to go with the safer, more down to earth approach. </TD></TR></TABLE>
I was saying that that is a reason it may be out of spec. The correct way to fix a caster problem is either repairing the frame or replacing the subframe, whichever is damaged. The ghetto way would be adjustable ball joints (like I am using to get more caster than normal). Traction bars ARE NOT a good way to increase caster.
Acurazor
May 24, 2009 12:19 PM
dr_latino999
Dec 6, 2007 12:22 PM
baiwldrnner
Honda Civic (2001 - 2005)
Aug 7, 2007 09:32 AM
Magick211
Oct 30, 2006 09:35 AM
si0385.
Dec 30, 2005 04:25 AM
