mp
Old May 17, 2005 | 08:31 PM
SPOOLINmatt's Avatar
Default mp
i have a brand new LS water pump because they sold me the wrong one but is it a big deal, or do i need to spend the extra cash on the GSR water pump with 22T gear? whats the difference. i know the GSR pump will spin slower than the LS waterpump at higher higher rpm.
Old May 18, 2005 | 02:36 AM
limpy's Avatar
Default Re: mp (SP00LIN)
switch out your timing belt too if you run the ls waterpump. the gsr has 1 more rib on the timing belt and will cause problems if you use the ls water pump and gsr timing belt.
Old May 18, 2005 | 09:04 AM
EG6 SiR's Avatar
Default Re: mp (limpy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpy &raquo;</TD></TR><TR><TD CLASS="quote">switch out your timing belt too if you run the ls waterpump. the gsr has 1 more rib on the timing belt and will cause problems if you use the ls water pump and gsr timing belt.</TD></TR></TABLE>
What he said.
JTTeG_X
Jul 17, 2013 10:50 AM
shortyz21
Nov 12, 2006 08:38 AM
JR Integra
May 3, 2004 04:17 PM
BoOsTiN Dc2
Feb 7, 2004 02:32 AM
spettinger
Feb 1, 2003 12:49 PM
