my CRX...
hi, i own an 87 Honda CRX. i bought it then found out that the engine sucks... so i was wondering the only way i can make this a sleeper car is to do an engine swap. so what should i swap for and how much will it be (estimate.) i looked into a B20 - CRV, would that be good or am i wasting my time?
stuffing in a B is alot of work and tight fit a DOHC ZC will make that thing rip also if I remember right a cheap used d16y8 could fit in and let her rip.
Swapping on 1st gen rexs is alot of work. search and you shall learn much.
what swap should i do that will get me the best results with no hop ups. a DOHC ZC or jdm B16. which is more work etc. can someone break it down for me, i dont know theses engines well.
well, your generation had a totally different set of mounts than later d series. it shared the mounts with the first gen integra, however.
you could swap in the d16a1 out of the integra, which is like a zc. this would be the easiest, but still hard if you don't have an si, because only the si's had fuel injection.
you'd have to rewire and replumb if you wanted fuel injection.
visit redpepperracing.com, they'll tell you what you need to know.
a b16 will go in, but it needs special mounts that only hasport makes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXJunkie »</TD></TR><TR><TD CLASS="quote">which motor is best for my car... DOHC ZC or B16, B18???</TD></TR></TABLE>
Best? They are all good engines. The decision really depends on how fat your wallet is.
The d16a1 would be the easiest.
Do you have an SI?
Do you have an SI?
no, it is a 87 CRX 2seater w/ hatch. i heard D motors arnt fast tho. i want to have about 250 hp on this thing. what do u think? do u have an estimate cost on all the motors?
Modified by CRXJunkie at 4:10 PM 5/18/2005
you can do 250 on a zc w/ a turbo... motors about $530 (hmotorsonline.com), mounts i dont know a price on... but yeh, you'll have to do some rewiring i'm pretty sure... but thats the best/easiest/cheapest way to go i do believe...
that and everyone and their DOG does a B-series swap... stick d-series, you can get some good kick out of em if you build em right and add the right options (ie t3/t4 turbo setup :D) and their cheap
zc motors seem to put out about 150hp. and B16 about 160-170. B16 is very difficult to get in tho?
Also, i think that an 88 or 89 integra dohc is stock for those cars? do they fit the same motor mounts as my car. and how many horses could i get outta one of them?
Modified by CRXJunkie at 4:53 PM 5/18/2005
zc motors only put out about 135-140 hp but i think that would be an easier swap than any of the other ideas that were mentioned...plus a y8 is a hydro tranny if i am correct and that year crx is cable.
the zc WILL NOT fit in without a lot of fabrication, but its the integras that have an engine VERY CLOSE to the zc, the d16a1, that will bolt right in.
but you need a lot of rewiring to do it.
also, if you buy special mounts, you can put a b series in there, the wiring's about the same, since you have to start FROM SCRATCH anyway.
i think your goal of 250 horses is completely unrealistic.
there's not much room to run f/i, etc. plus the EW chassis is pretty weak.
how much money do you have? what i'm planning on doing is just routing the whole trimmed down chassis harness into an ew, that will solve the wiring problem. now you have a problem with fuel delivery, some people say the fuel lines are fine, but if honda made them bigger on the fuel injection ones, just run bigger lines. etc, etc.
just visit redpepperracing, browse around. we can't tell you what engine's better for your needs. you need to be independent and research for yourself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myJDM89EF »</TD></TR><TR><TD CLASS="quote">if i am correct and that year crx is cable.</TD></TR></TABLE>
All CRX's are cable
All CRX's are cable
so the DOHC ZC is allot of work from what i hear.
so i think u r right that if im gunna have to do it from scratch i should just do a Btype. however with me and my brother and his friend iam sure we could do anything. however it might just be easier to just swap an integra D16A1 in. it would be easiest i think. but what kinda numbers would that spit out?
[quote]you can use any d-series tranny with a d-series motor so a y8 will mount up to his stock tranny or he could use a 88-91 si tranny if he wanted [quote]
your wrong
have you ever tried it on the 1g/3g crx civ or 1g teg engines? try it ..it wont bolt up
mounts are totally diff too
your wrong
superbeastcrx
Jan 9, 2006 12:05 PM
