What throttle cable???
Old May 17, 2005 | 06:17 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default What throttle cable???
I am putting an obd1 b16 into a 2000 civic ex, which throttle cable should i get, a del sol or a 2000 civic cable??? The one that was supplied w/ the swap was cut n i need to know asap, ty.
Old May 17, 2005 | 06:25 PM
Lord Helmet's Avatar
Default Re: What throttle cable??? (EJ8VTEC)
you'll be fine with your stock one.
Old May 17, 2005 | 06:47 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: What throttle cable??? (Lord Helmet)
thanx again
Old May 17, 2005 | 06:49 PM
boostedcivicsir's Avatar
Mr. Badwrench
if the ex mounting tab is the same distance from the throttle body you are fine, but obd1 and 2 b series are the same distance. so spent the 15 bucks and get the correct cable. del sol vtec, or 99-00 si will work.
Old May 17, 2005 | 06:57 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: What throttle cable??? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">if the ex mounting tab is the same distance from the throttle body you are fine, but obd1 and 2 b series are the same distance. so spent the 15 bucks and get the correct cable. del sol vtec, or 99-00 si will work.</TD></TR></TABLE>
figured that would be better, thanx
tr123gone
Jan 2, 2008 06:15 PM
sirt_eg
Apr 13, 2006 02:05 PM
guts311
Sep 3, 2004 05:42 PM
