Stuff for the LS Built ::thumbsup::
So as you all know i got some new parts for the LS motor that i am building as a school project. I also got a lil bit of machine work done. The motor should be in within 2-3 weeks. I will keep this updated as the project continutes
<U>The List of parts for the motor:</U>
-eagle rods
-je pistons 9:1 CR
-je rings
-exedy stage 2 clutch
-acl rod and main bearings
-arp head studs
-timing belt
-water pump
-NGK spark plugs
-cap and rotor
-omni power dual valve springs and retainers
-all new gaskets
-all new seals
<U>The list of the machine shop work goes like so:</U>
-balanced rods
-balanced pistons
-balanced crank
-decked the block
-honed the cylinders
-acid bathed the block
-resurfaced flywheel
**I am probably leaving something out but who knows**
here are the mmmmkk pictures:
and last but not least, some girl in my car
-eagle rods
-je pistons 9:1 CR
-je rings
-arp head studs
-timing belt
-water pump
-NGK spark plugs
-cap and rotor
-all new gaskets
-all new seals
-balanced rods
-balanced pistons
-balanced crank
-decked the block
Looking good as usual. But man you have to turbo this thing when it's said and done. Because the LS/Turbo is a crazy set up, especially when built. I'm sure you will catch the bug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H0LLiST3R »</TD></TR><TR><TD CLASS="quote">Looking good as usual. But man you have to turbo this thing when it's said and done. Because the LS/Turbo is a crazy set up, especially when built. I'm sure you will catch the bug.</TD></TR></TABLE>
It IS going turbo, i want to break it in first though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner »</TD></TR><TR><TD CLASS="quote">The girl looks mad depressed
hot 4dr </TD></TR></TABLE>
thats because it's a single cam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Na4LiFe »</TD></TR><TR><TD CLASS="quote">love it slammed
thanks man, as do i
if anybody has a set of silver 15inch rotas they would want to trade for these black c8's let me know. please be local
</TD></TR></TABLE>thanks man, as do i
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedingHatch »</TD></TR><TR><TD CLASS="quote">4 door hotness
hells ya
fourdoor<FONT COLOR="red">mafia</FONT> y0! for life!!
can't wait to boost, if anybody has any sick deals on turbos let me know. I am in the process of putting together a kit.
</TD></TR></TABLE>hells ya
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikciv666 »</TD></TR><TR><TD CLASS="quote">awww mother ******.....lookin nioce</TD></TR></TABLE>
hells ya tony, this is why i need your turbo kit...ASAP!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">looks exactly like my setup that Im getting together</TD></TR></TABLE>
^ Nice man, good luck
