JDM ITR pistons/ITR Rods
Old May 17, 2005 | 03:55 PM
LoserKid's Avatar
Default JDM ITR pistons/ITR Rods
Hello everyone, I have a 99 Civic with a B18c1 and right now I'm forced to buy new pistons/rings... I don’t want to go over the whole situation of why, but the pistons I had previous were USDM ITR pistons...
This time my motor has to be bored a bit so I was thinking of going with OS JDM ITR pistons for a bump in compression (I was going to prep for turbo but I would not be able to do a turbo forever) but my question Is with the JDM ITR Pistons set up I should see a slight difference. Right?
Also I was wondering if I got ITR rods to replace my GSR rods then I should be able to handle higher RPMS... I know in order to handle higher RPMS I would need a little stronger valve train which I have (ITR retainer, springs and Skunk 2 Valves).
Any help would be much appreciated...
I did do a search and have been searching this kind of information most of the day I just hope I did enough research to ask this?
Old May 17, 2005 | 10:29 PM
LoserKid's Avatar
Default Re: JDM ITR pistons/ITR Rods (B18c1Nick)
bump
Old May 17, 2005 | 11:01 PM
mtber's Avatar
Run JDM p30 pistons on your stock GSR rods. Upgrade your cams, valvesprings, retainers & get a chipped ecu.
Old May 18, 2005 | 07:28 AM
LoserKid's Avatar
Default Re: JDM ITR pistons/ITR Rods (mtber)
Thank you for your suggestions I appreciate them . Anyone else?
Old May 18, 2005 | 11:38 AM
. o 69 o .'s Avatar
civic type R pistons in OS and ITR cams and valve springs
Old May 18, 2005 | 11:39 AM
. o 69 o .'s Avatar
oh yeah, and a different intake manifold, Skunk2 or AEBS (once they finally release the GSR version)
Old May 18, 2005 | 05:14 PM
moto1320's Avatar
Default Re: JDM ITR pistons/ITR Rods (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">civic type R pistons in OS and ITR cams and valve springs</TD></TR></TABLE>
13:1 compression and ITR cams...no way. Unrelaible at that...
you should be very clear anout N/A for FI now. Hot cams and high compression are the opposite of where you want to go with boost.
I would run the JDM ITR pistons, the rods you have are fine just put ARP rod bolts in them. Your stock valves are better than skunk's, just upgrade the valvetrain with Omnipower and get some CTR cams or better, upgrade the LMA's and you'll have a good set-up.
Old May 18, 2005 | 09:39 PM
. o 69 o .'s Avatar
Default Re: JDM ITR pistons/ITR Rods (moto1320)
high compression and low boost yields big numbers if your tuner knows what he is doing. do a skinny search on that
Old May 18, 2005 | 11:08 PM
LoserKid's Avatar
Thanks for all the help everyone, but will I be ok with JDM ITR pistons, GSR Rods, ITR springs/retainers skunk2 valves and GSR cams or is that a set up for something to blow up?
Old May 19, 2005 | 05:14 AM
. o 69 o .'s Avatar
Default Re: (B18c1Nick)
just dont run crazy high boost, otherwise you will be fine. stick to 7-8 psi with good tuning and have fun
Old May 19, 2005 | 11:33 AM
LoserKid's Avatar
I don't want to boost anymore... I just want to know if that set up will be ok for daily driving?
Old May 19, 2005 | 02:12 PM
. o 69 o .'s Avatar
if you are not going to boost, go with the CTR pistons
joeybuilt
Dec 30, 2013 10:04 AM
fullboostin
Jun 26, 2005 06:42 PM
thegsrman
Dec 10, 2004 10:49 AM
