1990 TEG W/B16 swap+extras Buffalo NY Drive it home
Old May 17, 2005 | 03:52 PM
rubbersiidedown's Avatar
Default 1990 TEG W/B16 swap+extras $3500 Buffalo NY Drive it home
To many projects not enough time .
1990 Integra Gs 2 door 130k on body . Just inspected Body White interior is Black .no rust Texas car 2 years in Buffalo. Needs paint. and tuning
Jdm B16 with jdm pwo vtec ecu. 10k on the swap.
New with swap:Oil pump, water pump, distributer, oil pan gasket, timing belt ,tie rods,lower ball joints, both half shafts,fuel filter, cap and rotor,lightned crank pulley, and an after market aluminum radiator.
2 1/2 inch exhuast with high flow cat and apex muffler w/3in outlet
Tranny is original B18 with stag 3 clutch ( not great for the street ,but it will never slip )and a short throw shifter .
New rear brakes
Interior is stock except 3 inch tack mounted on dash
pass side auto seat belt isn't functioning correctly and the power sunroof motor is burned out but I have a complete sunroof that does work to replace it .
Extras
Comes with a set of front koni blues and neuspeed race springs 2 inch drop. And a full set of guages with white face and adjustable indaglo . Both used but in good condition .
$3500 b/o I may consider trades with cash
http://img260.echo.cx/img260/3650/p41200250qx.jpg
http://img219.echo.cx/img219/9749/p41200190ty.jpg
http://img243.echo.cx/img243/5603/p41200209cs.jpg
http://img243.echo.cx/img243/5416/p41200216ai.jpg
http://img243.echo.cx/img243/7528/p41200229pc.jpg
http://img188.echo.cx/img188/190/p41200236aq.jpg
http://img260.echo.cx/img260/7565/p41200244xo.jpg
napalm588
Apr 27, 2009 05:56 PM
eg95coup
Nov 19, 2007 09:06 PM
SoInCiv
Nov 28, 2005 04:08 PM
