HeliCoil Questions. Please Help!
Old May 17, 2005 | 02:32 PM
94B18Civic's Avatar
Default HeliCoil Questions. Please Help!
A few bolts stripped on my block and I need to heli-coil them. The size of the heli-coil thread repair insert is M10x1.5. Does anyone know what size drill bit I need to use to prepair the hole? Any other heli-coil tips would also be appreciated if someone has had luck doing this.
Thanks
Old May 17, 2005 | 04:11 PM
muldrick's Avatar
Default Re: HeliCoil Questions. Please Help! (94B18Civic)
Most HC kits usually have the recommended drill bit size on it. If you only have the helicoil, maybe go to a parts store and look at their kits to see if they list the drill bit size.
Old May 17, 2005 | 06:07 PM
94B18Civic's Avatar
Default Re: HeliCoil Questions. Please Help! (muldrick)
I have the heli-coil but there is no drill size on the packaging.
Old May 17, 2005 | 07:10 PM
rolansm's Avatar
From my file, for a M10 X 1.5 tap you need a 8.5 mm drill bit.
GoodLuck.
Top Ramen
Mar 31, 2006 12:57 PM
turbo boost
Aug 15, 2005 07:09 PM
