[FS] Akai MPC 1000 Sampler / Squencer
For Sale:
Akai MPC 1000 Sampler / Squencer.
Used only about 4-5 times.
IN PERFECT SHAPE
Comes with instructions, power cord, unit, memory card, all in original box.
$900 shipped in 48 states.
Manufacturer's product info:
OVERVIEW
The MPC 1000 is the first new Akai Midi Production Center model in over 5 years. While it keeps the features that made the MPC the most popular production unit in the industry, the 1000 has been redesigned to be portable and easier to integrate into today’s computer based home studio. As advancements are made in technology, products will become faster, more-powerful and less-expensive; and the MPC 1000 is no exception to this rule, so don't be fooled by its size and price. This is a very powerful machine for producing sample and beat based music, and a serious contender for the center piece of any production studio.
USES
• Sampling
• MIDI and Audio Sequencing
• Audio Manipulation
• Drum Programming
• Portable sample trigger/performance instrument
FEATURES
The MPC 1000 comes loaded with all the key features that made the MPC series the industry standard. It is a 16-bit, 44.1 kHz stereo sampler with 136 seconds of mono sampling time standard (expandable to 24m28sec). Sound wave patterns are displayed as wave forms, making it possible to edit samples both visually and aurally. Effects including pitch, LFOs, envelopes, time stretch and resample are available for use with all sounds. A new addition to the 1000 series includes two stereo effects and one master effect each of which are assignable to all sounds. These stereo effects include chorus, flanger, bit grunger, 4-band EQ (also available in master), compressor (also available in master), phase shifter, tremolo, flying pan and reverb. Another improvement over past MPC’s is the inclusion of a high pass filter, and both the low and high pass filters on the 1000 are 2-pole per voice.
The sequencer section is where the MPC has really derived its great reputation. With a 100,000 note memory and a capacity of up to 99 sequences that can be recorded in either linear or pattern-style, the 1000 is an extremely powerful machine. It also features a step edit mode, a loop recording function and 16 level, full level, tap tempo, auto punch and undo sequence features, making it extremely fast and intuitive to work with.
The hardware on the MPC 1000 offers enough connections to satisfy the most demanding recording applications. 2 new hardware features on the 1000 make it more viable in today’s (and tomorrow’s) computer based studios than its predecessors. The first improvement is the Compact Flash port which takes cards that range from 32MB (included) to 2GB. The second is the inclusion of a USB port that supports storage on MAC and PC via the Mass Storage Class USB standard. Basically, M.S.C. is a file management system that allows you to drag and drop sound files from the MPC to your computer's hard drive and vice versa, via the USB port. These 2 features negate the need for those slow floppy and zip disks, a weakness of previous MPC models.
The back panel of the 1000 is equipped with stereo 1/4” INs and OUTs, four 1/4” individual OUTs, digital S/PDIF IN and OUT, two MIDI INs and OUTs, a headphone OUT and two footswitch INs. The dimensions of the unit are 13” by 8” and it weighs less than 8lbs. Its sample reading capabilities are compatible with the MPC 2000XL, MPC 4000, Z4, Z8 and the S5000/6000.
KEY FEATURES
• Sampler, drum machine and multi-track MIDI sequencer in one instrument
• Extensive sample editing that includes cut and paste, time stretch, etc., with waveform display
• 44.1 kHz, 16-bit stereo sampling with 32-voice polyphony
• 16Mb RAM standard, expandable to 128Mb.
• Two separate effects processors and one main out effect processor; all which can be used simultaneously.
A 16 levels function giving you one sound on all pads with varied level, tuning, attack, decay or filter per pad.
• 4-pole filters (two 2-pole filters) filtering for each of the 32 voices.
• Large, trademark MPC velocity-and pressure-sensitive pads for programming
• Two Q-Link sliders for real-time performance control.
• Built-in Compact Flash slot (32MB-2GB cards supported) and USB port.
• Includes 32MB Flash memory card.
• 2 x MIDI IN and 2 x MIDI OUT.
• 32 MIDI channels.
• Internal preset sounds in flash.
• Powerful and easy-to-use MIDI sequencer offers a great alternative to complex computer-based sequences
• Step Edit mode for fast recording, viewing or editing of any event in a sequence
Am paypal verified.
Can supply vouch list
IN PERFECT SHAPE
OVERVIEW
USES
• Sampling
• Drum Programming
FEATURES
KEY FEATURES
• 32 MIDI channels.
Am paypal verified.
