nitrogen ?
Old May 17, 2005 | 01:19 PM
LoganMantits's Avatar
Default nitrogen ?
is nitrogen inflation good or bad?
Old May 17, 2005 | 01:22 PM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Default Re: nitrogen ? (LoganMantits)
wrong forum..........
go to the wheel and tire forum
Old May 17, 2005 | 01:24 PM
.BigSexy's Avatar
most hood white kid
i don't even know if that is possible...only real reason I would see this being effective is nitrogen is lighter than air(and I dont eve know if this is true) can someone else comply?
Old May 17, 2005 | 01:26 PM
civiccpedx's Avatar
Default Re: (egcoupe94)
i believe that it is lighter than air, but really im not sure, try the other forum
not only that the weight you would save would be pretty damn miniscule
Modified by civiccpedx at 5:41 PM 5/17/2005
Old May 17, 2005 | 01:36 PM
Frozen E's Avatar
H-T White Ops
Default Re: (civiccpedx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">i believe that it is lighter than air, but i also think that under the pressure required to fill a tire it would turn to liquid, but really im not sure</TD></TR></TABLE>
32 psi makes nitrogen turn to liquid????? Hahahahaha. Good ****. Great morning laugh. The nitrogen bottles we use at work have over 3,000 psi in 'em and it's a gas in the bottles.
The reason people use nitrogen in their tires is because the pressure of nitrogen doesn't fluctuate as much with temperature changes. So if you fill up your tire to 32 psi when it's 35* out it'll be damn close to that pressure when the temp gets to 80*. Great for people that need a consistent tire pressure. Say for example you're at an all day auto-x event that starts early in the morning. Once you dial in your tire pressure in the morning you shouldn't have to worry about it anymore for the rest of the day.
But the liquid at 32 psi thing is great. Thanks.
Old May 17, 2005 | 01:48 PM
h22 booster's Avatar
but who the hell should care if you are an average driver? Air is something like 75% nitrogen. And so what if a few times a year you have to stop at a free air pump or even one that costs a quarter. It seems like a gimmick created to charge a little more at the tire shop.
Old May 17, 2005 | 01:50 PM
civiccpedx's Avatar
Default Re: nitrogen ? (h22 booster)
actually it is like 82% nitrogen
Old May 17, 2005 | 01:53 PM
Default Re: nitrogen ? (civiccpedx)
comon...give or take some small percentage. It is primarily nitrogen was my point
brokenojoke
22
Nov 29, 2006 05:50 PM
SiRay13
Aug 10, 2006 09:20 PM
JDMInspired
Apr 17, 2006 02:59 PM
Total'd GSR
Dec 16, 2001 04:02 PM
