HX Dyno
Old Feb 5, 2002 | 12:02 PM
Spade's Avatar
Default HX Dyno
Old Feb 5, 2002 | 12:09 PM
Looose_R's Avatar
Default Re: HX Dyno (Spade)
nice
Old Feb 5, 2002 | 01:08 PM
nwdave's Avatar
Default Re: HX Dyno (b20bastard)
Cool
Is it me or are those SOHC VTEC numbers with a nice dose of torque?
Old Feb 5, 2002 | 01:14 PM
Spade's Avatar
Default Re: HX Dyno (delsolguy)
Actually there SOHC VTEC-E Numbers.
Old Feb 5, 2002 | 01:19 PM
96 SOHC VTEC's Avatar
Nice numbers.
I dyno'd my 96 Ex Coupe 5-speed with just an AEM CAI and I got 112.8hp and 101.2tq on the first run.
[Modified by 96 SOHC VTEC, 10:23 PM 2/5/2002]
[Modified by 96 SOHC VTEC, 5:05 AM 2/7/2002]
Old Feb 5, 2002 | 01:27 PM
Spade's Avatar
Default Re: HX Dyno (96 SOHC VTEC)
Yup, that is good.
Old Feb 6, 2002 | 05:55 PM
What were your mods for the run?
Old Feb 6, 2002 | 06:26 PM
nwdave's Avatar
I know...what I meant was this:
I wasn't expecting numbers that high; they were similar to a D16Z6/Y8 dyno but with better torque.
Old Feb 6, 2002 | 07:25 PM
seek167's Avatar
good #'s
Old Feb 6, 2002 | 08:06 PM
Default Re: HX Dyno (seek167)
Delsolguy, I had a tad better tq with my D16Y8 than Spade if you are saying the Hx's get better torque.
Old Feb 6, 2002 | 08:44 PM
FifthGearOnline's Avatar
hmmmm....makes me want to dyno now
Old Feb 7, 2002 | 08:08 AM
DragII's Avatar
nice torque band
Old Feb 7, 2002 | 08:18 AM
Spade's Avatar
Default Re: HX Dyno (DragII)
The only mods was a K&N Drop in. (BTW, not my HX.)
Found a baseline, I didn't want to waste money on a dyno for the stock HX. I plan to swap an EX manifold and see how much improvement I get from that. The hard part will be to keep from doing a mild Port and Polish before I dyno
[Modified by Spade, 9:20 AM 2/7/2002]
Old Feb 7, 2002 | 09:26 AM
sshaikh01's Avatar
Call me stupid.
But, shouldn't the dyno plot look the same for an HX. I mean a stock HX makes about 115 HP.
Old Feb 7, 2002 | 09:27 AM
Crazydave's Avatar
Default Re: HX Dyno (sshaikh01)
DANG!!!.. Your HX beat out my tired Ex...
I need to re-dyno my car now that I rebuilt my engine
Old Feb 7, 2002 | 09:30 AM
sshaikh01's Avatar
Your stock 00 hx specs from the factory
1.6 liter, 16-valve, SOHC VTEC™ engine 115hp
Old Feb 7, 2002 | 09:49 AM
dirtySOHC's's Avatar
nice numbers. i need to put my car up on a dyno and see what im pushin.
Old Feb 7, 2002 | 11:31 AM
Rogue108's Avatar
Default Re: HX Dyno (dirtySOHC's)
Those are good numbers. Strong motor, very little drivetrain loss.
Old Feb 7, 2002 | 12:14 PM
BlackDeuceCoupe's Avatar
HT White Ops
LOL! Yeah, Brandon is quite the legend around these parts; a true HX die-hard racer, or used to be. I haven't seen him around lately. I think he got that chart at a local Auto-X dyno day a few years back, but it shows why the typical HX will beat the typical EX 10 out of 10 times.
Despite Honda Corp horsepower CLAIMS, the HX and EX are evenly matched in this department. The difference is, EX's are carrying a couple-hundred extra pounds of pork around. Truth be known, I don't even bother racing EX's any more; not worth a ticket for a few stale laughs.
Anyway, the 'new' EX's come with VTEC-E motors in them now. Guess that says it all...
Old Feb 7, 2002 | 03:20 PM
nwdave's Avatar
I know the numbers are about the same or lower with the HX, but the curve certainly looks good.
Old Feb 15, 2002 | 10:08 AM
Spade's Avatar
https://honda-tech.com/zerothread?id=101349
Check the discussion about the HX vs. EX cams.
Old Feb 15, 2002 | 10:30 AM
HaUTSaauce's Avatar
New User
Old Feb 15, 2002 | 11:33 AM
VTC_CiViC's Avatar
Default Re: HX Dyno (BlackDeuceCoupe)
Hmm I dunno if i'd go that far. I raced only 2 HX's in my EX with only an intake and walked them both. The lighter weight and lighter rims are great benefit's for the HX, but ultimatley, the EX still makes more high end from 5.5k and up. The D16Y8 and D16Z6 baseline dyno's ive seen over the years have always shown 106-108whp stock, or say 7-8whp more than a bone stock HX which is right where it should be.
Old Feb 15, 2002 | 11:46 AM
Spade's Avatar
Default Re: HX Dyno (VTC_CiViC)
Yeah however, it all depends on the driver.
Remember from a 70 mph roll the HX will be in the sweet spot.
Off the line they suck period. I almost lost to a damn sentra with two people in it from the line but destroyed them from the roll.
Old Feb 15, 2002 | 11:51 AM
VTC_CiViC's Avatar
If anything I'd think it'd be the other way around. Seems to me like the HX has a far flatter torque curve than an EX does, and with the larger primary lobe attatched to the 2nd valve, the HX is actually breathing harder than the EX is untill the 3 lobe is engaged on the Y8. Racing from a roll where the EX can get a jump in VTEC is where the momentum slides over to our side. I've raced Si's from about a 70-75mph roll in 3rd (roughly 5500rpm for me) and get this, through 3rd gear we'd be dead even, he'd hit 4th before I did, and while he'd be in 4th, I'd PULL on the Si in 3rd.. of course once I hit 4th the Si tore me up, but the point is, while operating under VTEC, the Y8 is a far stronger motor than out of VTEC, with characteristic closer to that of the B16 (completley nutless till VTEC), this is the #1 reason why DX's and HX's are always door to door with me till 3rd when I can finally spend some worthwhile time between 5500 and 7300.
