Rear Swaybar problem on 92 Si Hatch
I have the 98 USDM rear arms and 5 lug conversion and i have the rear typeR sway bar but it does not bolt up.
It just bolts up to the arms of the typeR but does not bolt up to the frame or underside of the car.
How do you make this work?
just make sure you bag off the old nuts that are tacked to the inside of the subframe. if you use those, you will rip out of your subframe for sure..
i used big washers on my last two cars.. make sure you use them on both sides.
youll be fine
youll be fine
i have a 92 si hatch and there is no stock sway bar, so there's no place to bolt it to on except the arms(if not stock). i didn't get that from what everybody said, so that's probably the main problem.
Modified by TekSI at 5:32 PM 5/17/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TekSI »</TD></TR><TR><TD CLASS="quote">i have a 92 si hatch and there is no stock sway bar, so there's no place to bolt it to on except the arms(if not stock). i didn't get that from what everybody said, so that's probably the main problem.</TD></TR></TABLE>
No ****, you have to drill out some of the dimpled holes in the subframe. This isn't rocket science, people.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">No ****, you have to drill out some of the dimpled holes in the subframe. This isn't rocket science, people.</TD></TR></TABLE>
I just put that there so the others that posted there know there aren't any nuts or anything there from the factory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perk_hatch »</TD></TR><TR><TD CLASS="quote">Ok, my car is also a Si hatchback........so drill the holes and use some big *** washers and its good to go.</TD></TR></TABLE>
Yessir. That would be correct.
Just noticed you're from Lake Jackson...I grew up there
^Sammy]!.
Feb 9, 2004 07:39 PM
Cosworth
Feb 21, 2003 10:31 AM
