Clutch relay needs help
Old Feb 5, 2002 | 11:39 AM
sshaikh01's Avatar
Default Clutch relay needs help
I posted a thread ealier, i can't find it.
The issue was that when i turn the key to start the car, nothing happened, the engine didn't turned at all for like couple of seconds, and than in a second the car would start.
The car has started do this often these, days, and i discovered that when i let the clutch depress a little and than press it a little the car start in the first attempt.
so i'm guessing that it's my clutch rely.
I understand that its an easy process to replace it, and i wanted to know how much does it cost and how do i replace it. and where exactly it is located.
Thanks for your help in advance.
Old Feb 5, 2002 | 12:35 PM
bob01721's Avatar
Default Re: Clutch relay needs help (sshaikh01)
Unless I'm mistaken, it's a switch, not a relay. The switch is mounted on the pedal itself, way high up (you may have to lay on the floor and look up to see it).
Don't know about the price of a new one, but it may just need to be adjusted.
dannysolis92005
Apr 6, 2011 04:32 PM
Lextasy
Aug 13, 2008 08:09 PM
PaulHuston
Mar 18, 2007 11:16 AM
turbob16ef
Dec 5, 2005 12:42 PM
GroundZer0
Aug 15, 2003 12:05 PM
