cleanin out cat
Old May 17, 2005 | 09:40 AM
jayare05's Avatar
Default cleanin out cat
i cleaned out my cat yesterday after puttin on my dc header and today i threw a check engine light.. which didnt surprize me.. but is there anyway to keep it from coming back? besides the obvious buy another cat or high flow? i already pulled the negitive off the battery
Old May 17, 2005 | 09:45 AM
DagYo!'s Avatar
Default Re: cleanin out cat (jayare05)
obd1
Old May 17, 2005 | 09:59 AM
civictildeath's Avatar
is it a 4 wire o2 sensor??
if so, o2 simulator. see o2 sim install thread in my sig below for a place to buy($30) and how to install
Old May 17, 2005 | 10:40 AM
Farmer Brown's Avatar
Default Re: cleanin out cat (civictildeath)
a hollowed out cat will only hurt performance. And theres no reason not to run a cat. Get a high flow cat or at least a "test pipe"
And OBD1
Old May 17, 2005 | 10:44 AM
Deemeetree's Avatar
Electrician
Default Re: cleanin out cat (DagYo!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DagYo! &raquo;</TD></TR><TR><TD CLASS="quote">obd1 </TD></TR></TABLE>
Heh, that's a good one.
Indeed, with an OBD2+ vehicle, doing something like that will grab a CEL. Do like the others stated, O2 simulator and/or test pipe.
Old May 17, 2005 | 09:17 PM
jayare05's Avatar
Default Re: cleanin out cat (Dimitri_EG8 a.k.a. Dimi)
i assumed hollowing out the cat was basically the same thing as putting a test pipe on ?
Old May 17, 2005 | 09:19 PM
knockout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayare05 &raquo;</TD></TR><TR><TD CLASS="quote">i assumed hollowing out the cat was basically the same thing as putting a test pipe on ?</TD></TR></TABLE>
I thought the same thing. I mean, wouldnt a hollowed cat be just like a pipe, but with the looks of a cat? Cuz if I run a test pipe and a cop decides to do a random look under the hood and under the car, hes gonna noticed no cat. *shrug*
Old May 17, 2005 | 09:28 PM
jayare05's Avatar
Default Re: cleanin out cat (knockout)
well you need a cat for the visual part of inspection too in PA. will my car pass edmissions with this obd2? because what i had planned on doing is going to a part store when it is time for inspection and just buy a cat and throw it on, then when i pass i planned on taking the cat back..
Old May 17, 2005 | 10:36 PM
urnotfast's Avatar
hollowed out my cat on my em1 and got a ecg 02 sim from kteller.com and it works flawlessly i would definitely recomend it for your prob. some of those solder in resistors dont always work this does.
peace
eric
Old May 17, 2005 | 10:46 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: cleanin out cat (urnotfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urnotfast &raquo;</TD></TR><TR><TD CLASS="quote">hollowed out my cat on my em1 and got a ecg 02 sim from kteller.com and it works flawlessly i would definitely recomend it for your prob. some of those solder in resistors dont always work this does.
peace
eric</TD></TR></TABLE>
6thgenva
Welding / Fabrication
Oct 14, 2010 07:11 AM
6thgenva
Engine Management and Tuning
Oct 12, 2010 03:13 PM
DagYo!
18
May 17, 2005 05:57 PM
2lobes1engine
11
May 11, 2004 03:14 PM
Electron Si
15
Feb 11, 2004 02:57 PM
