tweeters in ej
Old May 17, 2005 | 08:52 AM
Mrfeee1's Avatar
Default tweeters in ej coupe
has anyone ever fit tweeters in door panels. with out the Ex tweeter pod. i want to put them flush on the upper front end of the panel.
Old May 17, 2005 | 09:13 AM
MikeD718's Avatar
Default Re: tweeters in ej coupe (Mrfeee1)
just trace on a circle and carefully cut it out w/ a really sharp knife. you could heat the plastic to help if you want.
Old May 17, 2005 | 09:19 AM
TallAssFilipino's Avatar
MikeD718: He's got an EJ1. I think he's already got the holes there.
Mrfeee1: Are you asking if anybody has every fit flushed tweeters into the pre-cut tweeter holes?
Old May 17, 2005 | 09:23 AM
Mrfeee1's Avatar
Default Re: tweeters in ej coupe (MDJ IKNJ)
i have a DX there are no holes. but i want to fit flush steeters. Im just worried that the tweeters might be too deep and will hit the inside of the door panel and not sit right.
Old May 17, 2005 | 03:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrfeee1 &raquo;</TD></TR><TR><TD CLASS="quote">i have a DX there are no holes. but i want to fit flush steeters. Im just worried that the tweeters might be too deep and will hit the inside of the door panel and not sit right.</TD></TR></TABLE>
O, ok. For some reason, I thought I saw you had an EJ1. Ummm, if you have the DX door panels, you shouldn't worry. You have room. To make sure, just take the door panels off yourself and check for yourself to be safe.
mac51o
Dec 5, 2010 05:08 PM
B18CYAAA
Nov 5, 2007 12:13 PM
Jdmglenn
Feb 14, 2007 02:11 PM
integra-modder
Audio / Security / Video
31
May 23, 2002 06:00 PM
