what oil should i use??
Old May 17, 2005 | 08:44 AM
WPG_5thgenprelude's Avatar
Default what oil should i use??
i am currently running mobile 1 5w 30, i used this oil through the winter and now it is getting close 2 summer here in wpg would i be better off using 10w30 or should i stick with 5w 30?
Old May 17, 2005 | 08:46 AM
lewdude's Avatar
Default Re: what oil should i use?? (WPG_5thgenprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WPG_5thgenprelude &raquo;</TD></TR><TR><TD CLASS="quote">i am currently running mobile 1 5w 30, i used this oil through the winter and now it is getting close 2 summer here in wpg would i be better off using 10w30 or should i stick with 5w 30?</TD></TR></TABLE>
Hey there fellow Winnipegger All you need is the 5w 30. It doesn't really matter what brand as long as you trust that brand. I have a 5th gen also, I burn quite a bit of oil. I just use Quaker State.
You should be fine.
Old May 17, 2005 | 09:31 AM
951dc5's Avatar
Default Re: what oil should i use?? (lewdude)
shoo..i'm using chevron oil... oil is oil!
Old May 17, 2005 | 09:41 AM
iwubmybb4's Avatar
Default Re: what oil should i use?? (Prelude951)
Royal Purple or Red Line oil.. they're good shiet
Old May 17, 2005 | 10:59 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: what oil should i use?? (iwubmybb4)
Stick with 5w-30. It is too cold up there. You don't want thicker oil. (10w-30)
How many miles on the engine?
Old May 17, 2005 | 11:24 AM
equinox's Avatar
oil isn't oil, but the stuff you're using right now is perfect for the weather conditions in Canada
Old May 18, 2005 | 06:23 AM
RemerLex11's Avatar
Default Re: what oil should i use?? (lude_roller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude951 &raquo;</TD></TR><TR><TD CLASS="quote">shoo..i'm using chevron oil... oil is oil!</TD></TR></TABLE>
not at all! but you'll be fine sticking with mobile 1 5w30, that's what I use all year around.
FoxRiderH22A
Jul 3, 2009 06:30 AM
TyPeS-TunEr
12
Mar 22, 2007 06:05 PM
return_2020
Jun 21, 2005 01:40 PM
HUBB
12
Apr 24, 2004 01:53 PM
