o2 power wire color
Old May 17, 2005 | 08:36 AM
hookedonvtec's Avatar
Default o2 power wire color
im going to run a new slim fan in my engine and i was wondering if anyone knew what color the o2 sensor power wire was. i want the fan to stay on all the time to help keep the engine cool. thanks guys
Old May 17, 2005 | 08:42 AM
Deemeetree's Avatar
Electrician
If the fan doesn't come wired like that from factory, don't do any Algerian Engineering on it and hack it up. If you have overheating problems, fix it the proper way. I live in 100* heat and at a stand still, my temp gauge NEVER goes up (Brownsville, Texas). It is wired stock from factory, so it comes on when it reaches a certain temperature.
Old May 17, 2005 | 08:47 AM
Default Re: (Dimitri_EG8 a.k.a. Dimi)
no the fan thats in there now works fine. its just so huge. i wired the slim fan into the stock wiring and the fan didnt come on and caused my car to overheat until i started moving. i want the fan on all the time anyways because it helps the motor stay cold. there are no overheating problems with my car as it sits, just when i put the slimfan on cause the thing wont turn on. i put the slim fan on the battery to make sure it works and it works fine
Old May 17, 2005 | 09:10 AM
Default Re: (hookedonvtec)
Old May 17, 2005 | 09:15 AM
WildPig's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hookedonvtec &raquo;</TD></TR><TR><TD CLASS="quote">no the fan thats in there now works fine. its just so huge. i wired the slim fan into the stock wiring and the fan didnt come on and caused my car to overheat until i started moving. i want the fan on all the time anyways because it helps the motor stay cold. there are no overheating problems with my car as it sits, just when i put the slimfan on cause the thing wont turn on. i put the slim fan on the battery to make sure it works and it works fine</TD></TR></TABLE>
Is that a question?
Go out and buy yourself the helms manual for your car and use the wiring diagrams in it to wire it up properly, there is a reason that the fan doesn't run ALL THE TIME.........
youstolemybeer
Dec 20, 2016 07:31 AM
samhfoster
14
Oct 1, 2014 06:03 PM
importslife
Feb 6, 2005 05:51 PM
SpoonFedEF7
May 19, 2003 08:53 PM
