fully built and i mean fully built!!
i just finished my b16 project and i want to make it faster but the only thing i can do is turbo or make it a 1.8. to give u guys an idea the block is sleeved, arias pistons and eagle connecting rods. comp is 11:5:1. new bearings water pump and type r oil pump. head is ported and polished with a match port type r manifold and match port throttle body. jun stage 3 cams and jun valvetrain and the list goes on. so wut do u guys think i should do. turbo or bore it to a 1.8?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrevnef »</TD></TR><TR><TD CLASS="quote">i just finished my b16 project and i want to make it faster but the only thing i can do is turbo or make it a 1.8. to give u guys an idea the block is sleeved, arias pistons and eagle connecting rods. comp is 11:5:1. new bearings water pump and type r oil pump. head is ported and polished with a match port type r manifold and match port throttle body. jun stage 3 cams and jun valvetrain and the list goes on. so wut do u guys think i should do. turbo or bore it to a 1.8?</TD></TR></TABLE>
Turbo?? why would you think of putting a turbo on something with 11.5:1 c/r?
You should have went with 84mm or higher sleeves if you wanted more displacement.
I think you should drive it the way it is. Setup sounds like a good all motor street setup. Actually almost the exact setup i have right now minus mine is a ls/vtec with all same head work you have.
84mm + ITBs = all motor madness
Definitely bore the sleeves out to 84mm and maybe even go with a higher compression piston to let those cams breathe more.
^^ indivdual throttle bodies.
Just Get a stroker kit and bore out the engine to 85mm with a Darton sleeve kit. We did that on a B18C5, it now displaces 2.2L, but looks stock form the outside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bjorn20 »</TD></TR><TR><TD CLASS="quote">whats itb?</TD></TR></TABLE> i get it confused with "in the butt" and "individual throttle bodies"
you're at a cross roads now:
personally id consider going b20 at where you are, why you ask?
you can sell that sleeved 1.6 block with pistons complete for more $$, since youd have to buy bigger bore pistons if you stoke the motor you have.
b20b with high comp 84mm pistons, like JE
ITB's need to be tuned really well, and they dont exactly get good gas milage, and they are quite loud. on a daily driver i dont know how good of an idea that might be, since you have the opion of going larger displacement first...
but they rock hardcore, sound SICK no denying it, also pretty damn expensive last time i priced out a few different sets.
JDMH22Prelude
Jun 22, 2006 09:44 AM
highrevnef
May 17, 2005 11:15 AM
