my air doesnt blow cold at a stop...
Old May 17, 2005 | 07:44 AM
darkfx's Avatar
Default my air doesnt blow cold at a stop...
my a/c doesnt work when im sitting in a parking lot or at a stoplight for a couple minutes.. but when im cruising down the highway, its ice cold.. does it need to be recharged? if so, where is the low pressure port??
97 base
thanks
Old May 17, 2005 | 08:22 AM
boomslang's Avatar
Default Re: my air doesnt blow cold at a stop... (darkfx)
It's normal for the AC to be warmer at idle. Then AC compressor is belt driven by the crank, at idle you aren't working the compressor very hard.
Check your belt tension. However, it's probably just something you will have to live with.
Old May 17, 2005 | 08:26 AM
SilverPanda's Avatar
mine does that too, probably because when you are driving more air goes into that little air conditioning thingy on the front of the car? and when its just sitting there, theres no cold air going in.
Old May 17, 2005 | 09:12 AM
darkfx's Avatar
yeah.. this is the first car that i've owned thats done this.. the air is hot when im sitting
Old May 18, 2005 | 04:54 AM
trvis's Avatar
Default Re: (darkfx)
mine too
the light on my climate control actually goes out when im sitting
Old May 18, 2005 | 07:52 AM
Default Re: (trvis)
i guess we just have to live with it
Old May 18, 2005 | 10:40 AM
flyrod's Avatar
Default Re: (vtech22)
make sure the fans work. With the car stopped and the AC on both radiator fans should turn on when the compressor does, so that the condenser can dissipate heat. Make sure they are wired right too. I've seen them wired wrong and blow air out the front of the car.
Old May 18, 2005 | 10:48 AM
SpeedMachine's Avatar
Default Re: (flyrod)
try filling up that freon
Old May 18, 2005 | 10:55 AM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: (SpeedMachine)
thats wierd i have a UR crank pully and it slows the ac down in idle put mines still cold as when im driving i would check the freon and make sure the fans come on when the ac is on
Old May 18, 2005 | 02:14 PM
junbb1's Avatar
Default Re: (raylude)
youre fans are probably not working. primarily the condenser fan (on drivers side).
Murf72
Honda CR-V & Element
Jun 17, 2014 06:45 AM
EP_three
May 15, 2007 01:08 PM
Wsteun
May 29, 2006 11:23 AM
abeaujuin
May 9, 2004 08:18 PM
