injectors are all the same sohc's d15 d16?
Old May 17, 2005 | 07:37 AM
civic_tuned's Avatar
Default injectors are all the same sohc's d15 d16?
i was told by a mechanic that i had to change one of the injectors and i have a friend of mine who has a 93 ej1 d15 and i wanted to know if his injectors are the same cc's as mine. I have a 94 ej1 d16z6. what a do?
Old May 17, 2005 | 07:47 AM
extra cam needed's Avatar
From: americas finest, calee fourn ya, united states
Default Re: injectors are all the same sohc's d15 d16? (civic_type_r)
Yes! I believe they will fit. I know they should have the same output 240. For those years and more I believe the sohc and dohc had the same output.
Old May 17, 2005 | 07:53 AM
SkoundrelUSA's Avatar
cute little bastard
B7 and Z6 injectors are the same, but I can't say for the injectors off a VX or CX. Theres always a huge debate over it. I'm pretty sure the VX injectors are around the 170-190cc range b/c I tried them in my B16 and I couldn't drive more than a block...
Old May 17, 2005 | 08:25 AM
Deemeetree's Avatar
Electrician
Indeed.
D15B7/D16Z6:
06164-P06-A02
06164-P10-A02
D15Z1/D15B8:
06164-P05-A02
06164-P09-A00
Z6/B7 are 240cc
Z1/B8 are 190cc
I do believe these are the correct ranges from what I've read before.
Has to be a different cc rating on them. Especially, since they are the "economy" engines that are made for gas mileage, not power.
Old May 17, 2005 | 08:31 AM
BauleyCivic's Avatar
Risky Business
Default Re: (Dimitri_EG8)
I think the Z1/B8 ones might be 180cc, not sure though.
Good info from Dimi though
Old May 17, 2005 | 08:45 AM
Deemeetree's Avatar
Electrician
Default Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
Good info from Dimi though </TD></TR></TABLE>
Tanky.
Old May 17, 2005 | 09:08 AM
Default Re: (Dimitri_EG8 a.k.a. Dimi)
I can understand why the B8-8-valve and the Z1 vtec-E. So what's up with the VX and CX I figured they'll be the same as the LX/DX, those injectors will fit in a b-series correct? (b-series also 240cc certain years) or am I mistaken?
Old May 17, 2005 | 09:10 AM
Deemeetree's Avatar
Electrician
The VX is the Z1 and the CX is the B8. I think you got it confused.
Old May 17, 2005 | 09:18 AM
Yes I did! I thought the were just engine options that sometimes come in those models not all of them. Thanks. (now I see why alot of ppl with CX and VX models opt for the b-series I had a feeling it wasn't just bc of the lighter weight)
BxBomber712
Feb 4, 2010 04:45 PM
92ehatch
Feb 8, 2007 04:47 AM
motoman358
Feb 4, 2006 12:06 PM
philafelman
May 11, 2004 04:22 PM
Civic Racer X 7
Aug 9, 2003 02:00 PM
