will an exhaust made for an 92-95 hatch fit a 92-95 2 door?
i wanted to get an magnaflow cat back for my 93 coupe dx 1.5L but magnaflow make only for 1.6L engine for the 2 door and in 1.5L make it for Hatchback, CX/VX what would be required to fit or it dosen't matter if it 1.6 or 1.5 help me out here.
Modified by CivicHP at 9:06 AM 5/17/2005
Magnaflow def makes a catback for 92-95 Hatches that are not VX/CX because I have one. It should be under Si/Dx. Heres mine:
http://elit3.com/upload/magnaflow.wmv
Edit: **** I suck at reading. To answer your question, I'm pretty sure (90%) that whether its 1.6l or 1.5 doesn't matter. The cat should still bolt up to the pipe fine. Mine came with a straightpipe for some reason so you wont be **** outta luck if it doesnt bolt up
Modified by SkoundrelUSA at 12:40 PM 5/17/2005
I think the B pipes are the same but the axlebacks are different...I might be wrong though. Sedan and coupe exhausts are the same though.
Just the exhaust made for your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicHP »</TD></TR><TR><TD CLASS="quote">so a 92-95 2dr dx 1.6L and 1.5L is the same piping and will bolt on?</TD></TR></TABLE>
Yes sir
Yes sir
m0nkey
Mar 29, 2005 06:58 PM
slthatch
May 9, 2004 06:18 PM
