Sloppy SHift Linkage
Old May 17, 2005 | 06:54 AM
2kTeg's Avatar
Default Sloppy SHift Linkage
So the new sohc zc is in its turbo everything runs real good i hope to get some times this weekend but, the only problem that i am having is the shifter feels like ***. It just feels really sloppy when i put it into gear it will still move from side to side. Hopefully this is something i did wrong and not the throughout bearing, whatcha think?
Old May 17, 2005 | 07:31 AM
vegaskurt's Avatar
Default Re: Sloppy SHift Linkage (2kTeg)
If you replace the bushings that will help some of the slop. Also, (in my case) the bitch pin that holds the linkage to the tranny could be worn or have some play in it.
Old May 17, 2005 | 08:00 AM
2kTeg's Avatar
i replaced one of the bushing and i couldn't find my bitch pin so i stuck a nut/bolt combo through it could this be the reason for the extreme sloppyness? I mean this **** rediculously sloppy. thanks
Old May 17, 2005 | 08:45 AM
Kryogen's Avatar
could be the problem you can get a new pin from honda for like $3
Old May 17, 2005 | 09:08 AM
MrPotatoeHead's Avatar
Default Re: (Kryogen)
YES THATS YOU PROBLEM
Old May 17, 2005 | 10:35 AM
2kTeg's Avatar
thanks ill try that when i get home and let you all know
Jay_Mills
Jan 4, 2013 01:30 PM
DOUBLExDEUCEx22
Dec 19, 2009 01:25 PM
1kleenef
Jun 6, 2008 03:53 PM
bee16a
Jan 10, 2006 01:21 PM
