Will a 92-00 civic coupe exhaust fit a 94-01 integra 4dr?
Old May 16, 2005 | 10:16 PM
b00sted4dr's Avatar
Default Will a 92-00 civic coupe exhaust fit a 94-01 integra 4dr?
Ok i have heard that the exhaust for a 92-00 civic will fit a 94-01 integra sedan. Is this true?
If anyone does happen to know, is the whole exhaust or just the axle back?
TIA
Old May 17, 2005 | 01:34 AM
shorto85's Avatar
The 4dr integras are longer than the civic coupe so the whole exhuast system wouldnt be long enough.
Im not sure if just axle back would fit or not... might end up a little short
Old May 17, 2005 | 06:44 AM
b00sted4dr's Avatar
Default Re: (shorto85)
hmm... Thanks you for your reply
Anyone else?
Old May 17, 2005 | 08:39 PM
b00sted4dr's Avatar
Default Re: (b00sted4dr)
TTT
Old May 18, 2005 | 06:07 PM
b00sted4dr's Avatar
Default Re: Will a 92-00 civic coupe exhaust fit a 94-01 integra 4dr? (b00sted4dr)
bump
Old May 18, 2005 | 09:29 PM
viet_boi_racin's Avatar
i got a 95 GSR coupe cat back to fit into my 94 LS sedan..only problem is the heatshield in the back infront of the LCA's touch the piping so it'll rattle.. so what i did was cut that off about an inch.. and its fine.. the tip is lil bit shorter then the ones made for a sedan but its not really that bad.. hangers line up .. i can try to get pics later
Old May 19, 2005 | 06:15 AM
b00sted4dr's Avatar
Default Re: Will a 92-00 civic coupe exhaust fit a 94-01 integra 4dr? (viet_boi_racin)
if you can get pics that would be great
Im actually using a stock coupe integra axle back right now and its too short. It sits behind my bumper. Seems like the hangers are positions closer to the tip and the tip is shorter.
I have heard though, that an ek coupe should bolt up to a 4dr integra..
source: http://passwordjdm.com/product...tails
PoweredByMugen
Mar 21, 2014 07:51 AM
DELshow
Sep 25, 2010 08:09 PM
stiffdogg06
May 20, 2009 04:05 PM
MeanGreenEG9
Mar 22, 2003 08:09 PM
Minorgliche
Nov 19, 2002 05:41 AM
