DO ITR seat bolt into EG and EK?
Old May 16, 2005 | 09:16 PM
dirt_06's Avatar
Default DO ITR seat bolt into EG and EK?
New to Honda's and I haven't been able to get a straight answer from the locals. Will the ITR seats Bolt right into an EG or EK with no modding or custum fab of brackets?? Any help would be appreciated.
Old May 16, 2005 | 09:18 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: DO ITR seat bolt into EG and EK? (kongvu)
EG
Deemeetree's Avatar
Electrician
With the entire railing in place, they should. If not, you can always try and mount the Civic's rails onto the seat.
Old May 16, 2005 | 09:19 PM
SOHC4life 96's Avatar
If you swap the rails from the two seats yes, otherwise no it's not a direct fit in an "EK".
EK k kay's Avatar
Search.
The answer is yes. 3 bolts will bolt in. If you want all 4 bolts to go in, swap the inner rail from the eg seat for an eg and swap the inner rail from the ek for an ek.
Old May 16, 2005 | 09:23 PM
dirt_06's Avatar
Default Re: DO ITR seat bolt into EG and EK? (chowmien)
Do I have to weld the rail onto the seat or are they bolt on??
Old May 16, 2005 | 09:49 PM
balistik's Avatar
all 4 bolts should fit into eg with a little modding. wiggling and what not. ek you'd need to switch the rails.
Old May 16, 2005 | 10:58 PM
92b16vx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien &raquo;</TD></TR><TR><TD CLASS="quote">Search.
The answer is yes. 3 bolts will bolt in. If you want all 4 bolts to go in, swap the inner rail from the eg seat for an eg and swap the inner rail from the ek for an ek.</TD></TR></TABLE>
You DO NOT have to swap anything to put Integra ITR (or other model) seats into an EG/EH chassis.
Old May 16, 2005 | 11:01 PM
mr.sky's Avatar
straight swap into an eg dude, ek needs modification
Old May 20, 2005 | 09:00 PM
dirt_06's Avatar
Default Re: (mr.sky)
Mr sky did you do the swap and are you speaking from personal experience?
Old May 20, 2005 | 09:32 PM
rodrez.'s Avatar
Ongoing debate. I've bolted Integra LS, GSR, and ITR seats into friends EH Civic's before, no problem, all 4 bolts lined up. Tried to bolt ITR and OEM Recaro's into my car (93 Civic Si) and my friends 92 Civic CX, and only 3 bolts would line up, the 4th wasn't even close. Some on HT have had a similar experience.
Old May 20, 2005 | 09:34 PM
JL's Avatar
JL
i dunno, have any of you bolted the two rears in and then adjusted the seat position (forward and back) sometimes one rail is a "tooth" off. i dunno, just a though
Old May 21, 2005 | 12:18 AM
92b16vx's Avatar
When I put my first set of ITRs in, the last hole was off, but I just loosened the others and moved it around, they all line up eventually.
Old May 21, 2005 | 12:40 AM
92b16vx's Avatar
Default Re: DO ITR seat bolt into EG and EK? (rodrez.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez. &raquo;</TD></TR><TR><TD CLASS="quote">Tried to bolt ITR and OEM Recaro's into my car (93 Civic Si) and my friends 92 Civic CX, and only 3 bolts would line up, the 4th wasn't even close. </TD></TR></TABLE>
It's possible they were misrepresented CTR seats, that would have that effect.
Old May 21, 2005 | 01:23 AM
rodrez.'s Avatar
Default Re: DO ITR seat bolt into EG and EK? (92b16vx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx &raquo;</TD></TR><TR><TD CLASS="quote">
It's possible they were misrepresented CTR seats, that would have that effect.</TD></TR></TABLE>
True for the JDM Recaros, but the ITR's were US, so they should have fit.
Old May 21, 2005 | 01:36 AM
92b16vx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez. &raquo;</TD></TR><TR><TD CLASS="quote">True for the JDM Recaros, but the ITR's were US, so they should have fit. </TD></TR></TABLE>
Ahhh, I see, that is strange then. Is it possible the rails were swapped before you got a hold of them for another chassis? Or did you pull them directly?
Old May 21, 2005 | 02:58 AM
OsNApArAvEr's Avatar
i installed 2001 gsr seats into my eg today no problem
jshaw23
Jul 26, 2010 08:38 PM
shift_knob
Nov 25, 2009 12:42 PM
. o 69 o .
May 27, 2004 08:14 AM
eg5
Nov 21, 2003 12:01 PM
vtecdc2
11
Oct 13, 2003 02:26 PM
