Idle question... 94 LS
Old May 16, 2005 | 08:03 PM
tastim's Avatar
Default Idle question... 94 LS
Recently my idle has dropped a couple hundred RPMs from about 750 to 500... and occassionally dipping below even that. Well, I figured, no problem, I'll just give the adjustment screw a little turn and fix the problem... well.... what I could have sworn was the idle adjustment screw doesn't seem to be affecting the RPMs at all... and I've cranked the thing out (counter-clockwise) 5-6 full turns....
All that happens is the whistle coming from my intake seems to get more noticeable... which leads me to believe that the screw I am turning is actually the air flow adjustment screw....
The problem? Well, I see no other screws on the throttle body.... so where the heck is the idle adjustment?
A related question.... since my timing was recently adjusted to factory specs a few months ago (16 degrees) at 750 +- 50 rpm, could this be what is affecting my fuel economy now that my idle has dropped off? I'm getting about 50 miles less per tank than I was a month ago, before my idle dropped off.....
Modified by tastim at 9:33 PM 5/16/2005
Tyrant_007
Mar 28, 2011 08:01 PM
followthadollar
Apr 21, 2010 02:46 PM
ciiivic89
Feb 9, 2009 07:03 PM
integra714
May 18, 2005 07:38 AM
whoobeedoobee
Jun 25, 2004 06:39 AM
