ferea valvetrain rpm?
Old May 16, 2005 | 07:05 PM
alexsracing's Avatar
Default ferea valvetrain rpm?
I have the full ferrea vlavetrain setup (valves, retainers,springs)P&P on a d16z6(cp pistons,eagle rods) with stock cam
how many rpm can these take?
Old May 16, 2005 | 09:40 PM
HEAD's Avatar
Default Re: ferea valvetrain rpm? (alexsracing)
10,500 or so
Old May 17, 2005 | 09:38 AM
on a sohc? same as the dohc
Old May 17, 2005 | 12:39 PM
msmotorsports's Avatar
It really doesn't matter how high you can rev. Ferrea parts can spin up to 11,000 with no worries. However, reving that high with stage 2 cams or sometimes stage 3 won't make a difference. In fact you will lose power when reving higher than what the cams were made to do. What type of cams are you using? Check with the maufacturer and find out what the usable powerband is. Then you will know where to set the rev limiter.
Old May 19, 2005 | 11:23 PM
I might be going with a SC52 turbo so I will need more rpm, I hear you can go 8,000 on a stock z6 cam so I'll shoot for 8-8.5k due to turbo lag
gsrjdm00
Nov 18, 2008 11:31 AM
matix
Sep 29, 2004 05:10 PM
J-Spec EG
May 28, 2004 06:33 AM
ActiveAero
Dec 5, 2003 02:45 PM
